Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet HMC8142 (Analog Devices) - 3
Описание81 GHz to 86 GHz, E-Band Power Amplifier with Power Detector
Страниц / Страница16 / 3 — Data Sheet. HMC8142. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. …
ВерсияA
Формат / Размер файлаPDF / 319 Кб
Data Sheet. HMC8142. SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit
Data Sheet HMC8142 SPECIFICATIONS Table 1 Parameter Min Typ Max Unit
RF Amp Single Power Amp 86GHz 4.5V 25Pin Bare Die Tray
ЧипСити
HMC8142
31 430 ₽
HMC8142
33 071 ₽
HMC8142-SX
Akcel
HMC8142
Вебинар «Как выбрать идеальный силовой модуль: решения SUNCO для силовой электроники» (03.12.2024)
TA = 25°C, VDDx = 4 V, IDD = 450 mA, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit
OPERATING CONDITIONS Radio Frequency (RF) Range 81 86 GHz PERFORMANCE Gain 19 21 dB Gain Variation over Temperature 0.02 dB/°C Output Power for 1 dB Compression (P1dB) 22.5 25 dBm Saturated Output Power (PSAT) 26 dBm Output Third-Order Intercept (OIP3) at Maximum Gain1 29 dBm Input Return Loss 12 dB Output Return Loss 8 dB POWER SUPPLY Total Supply Current (IDD)2 450 mA 1 Data taken at output power (POUT) = 12 dBm/tone, 1 MHz spacing. 2 Adjust VGGx from −2 V to 0 V to achieve the total drain current, IDD = 450 mA. Rev. A | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
