Datasheet Texas Instruments TL081MFKB — Даташит
Семейство | TL08xx |
Серия | TL081 |
Модель | TL081MFKB |
Операционный усилитель с входом JFET 20-LCCC от -55 до 125
Datasheet TL081, TL081A, TL081B, TL082, TL082A, TL082B, TL084, TL084A, TL084B
PDF, 2.5 Мб, Версия: I, Файл опубликован: 27 май 2015, Страниц: 51
TL08xx JFET-input operational amplifier
JEET-INPUT OPERTIONAL AMPLIFERS | |||
TL081MFKB | по запросу | ||
TL081MFKB Texas Instruments | по запросу | ||
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | TLE2071MFKB |
Replacement Code | F |
Additional Features | Vos Adj Pin |
Approx. Price (US$) | 0.12 | 1ku |
Архитектура | FET |
CMRR(Min)(dB) | 70 |
CMRR(Typ)(dB) | 86 |
GBW(Typ)(MHz) | 3 |
Input Bias Current(Max)(pA) | 200 |
Iq per channel(Max)(mA) | 2.8 |
Iq per channel(Typ)(mA) | 1.4 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 18 |
Operating Temperature Range(C) | -40 to 85 0 to 70 |
Output Current(Typ)(mA) | 10 |
Package Group | PDIP SO SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (CDIP) See datasheet (PDIP) |
Rail-to-Rail | In to V+ |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 13 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 36 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 7 |
Vn at 1kHz(Typ)(nV/rtHz) | 18 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 6 |
RoHS | Не совместим |
- Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation.
Серия: TL081 (15)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
