Datasheet Broadcom HCPL-2232 — Даташит
Very High CMR, Wide VCC Logic Gate Optocouplers
Купить HCPL-2232 на РадиоЛоцман.Цены — от 156 до 21 406 ₽ 53 предложений от 28 поставщиков Оптопара, 2 канала, 3.75 кВ, 5 Мбод, Поверхностный Монтаж DIP, 8 вывод(-ов) | |||
HCPL2232-000E Broadcom | 156 ₽ | ||
HCPL-2232-300E | 197 ₽ | ||
HCPL-2232-500E Broadcom | от 234 ₽ | ||
HCPL-2232-500E Avago Technologies | по запросу |
The dual-channle optocoupler is an optically-coupled logic gate.
It contains an GaAsP LED. The detectors have totem pole output stages and optical receiver input stages with built-in Schmitt triggers to provide logic-compatible waveforms, eliminating the need for additional waveshaping.
A superior internal shield guarantees common mode transient immunity of 10 kV/ms at a common mode voltage of 1000 volts.
The electrical and switching characteristics of the HCPL-2232 is guaranteed from -40 degrees C to 85 degrees C and a VCC from 4.5 volts to 20 volts. Low IF and wide VCC range allows compatibility with TTL, LSTTL, and CMOS logic and result in lower power consumption compared to other high speed couplers. Logic signals are transmitted with a typical propagation delay of 150 ns.
HCNW2201 HCNW2211 HCPL-0201 HCPL-0211 HCPL-2201 HCPL-2202 HCPL-2211 HCPL-2212 HCPL-2231 HCPL-2231
- Optocouplers and Opto-Isolators > Industrial Plastic > Digital Optocouplers > 5MBd Digital Optocouplers
HCPL2232, HCPL 2232
