Datasheet Diodes PI4ULS5V108ZBAEX — Даташит
Производитель | Diodes |
Серия | PI4ULS5V108 |
Модель | PI4ULS5V108ZBAEX |
8-Bit Bi-Direction Level Shifter for Open-Drain and Push-Pull Application
Купить PI4ULS5V108ZBAEX на РадиоЛоцман.Цены — от 47 до 13 258 ₽ 15 предложений от 8 поставщиков 8-Bit Bi-Directional Level Shifter For Open-Drain And Push-Pull Application | |||
PI4ULS5V108ZBAEX Diodes | 47 ₽ | ||
PI4ULS5V108ZBAEX Diodes | 49 ₽ | ||
PI4ULS5V108ZBAEX | 13 258 ₽ | ||
PI4ULS5V108ZBAEX Diodes | по запросу |
The PI4ULS5V108 supports up to 100 MHz up translation and greater than 100 MHz down translation at <= 30pF cap load and up to 40 MHz up/down translation at 50pF cap load which allows the LSF family to support more consumer or telecom interfaces (MDIO or SDIO).
It has bidirectional voltage translation without the need for DIR pin which minimizes system effort (for PMBus, I2C, or SMbus).
The PI4ULS5V108 supports 5 V tolerance on IO port which makes it compatible with TTL levels in industrial and telecom applications. It is able to set up different voltage translation levels on each channel which makes it very flexible.
Корпус | TSSOP (L20) MSL1 Sn |
Auto Direction Sensing? | No |
Bits Needed | 8 |
Max Signal Rate | 100Mhz |
Prop Delay | 2.2ns |
Shift | Bi-Directional |
Temperature | -40 to 125 |
Translation From (V) | 0.95 to 3.3 |
Translation To (V) | 1.8 to 5 |
Серия: PI4ULS5V108 (1)
- PI4ULS5V108ZBAEX
- Connectivity & Timing > Interface > Universal Level Shifter / Voltage Translation (ULS)
