Datasheet Linear Technology LTC2335-18 — Даташит
Серия | LTC2335-18 |
18-Bit, 1Msps 8-Channel Differential ±10.24V Input SoftSpan ADC with Wide Input Common Mode Range
Datasheet LTC2335-18
PDF, 2.1 Мб, Язык: анг., Файл закачен: 20 авг 2017, Страниц: 40
IC ADC 18BIT SAR 48LQFP | |||
LTC2335CLX-18 Analog Devices | 1 686 ₽ | ||
LTC2335ILX-16 Linear Technology | по запросу | ||
LTC2335ILX-18 Analog Devices | по запросу | ||
LTC2335HLX-18 Analog Devices | по запросу |
LTC2335CLX-18#PBF | LTC2335HLX-18#PBF | LTC2335ILX-18#PBF | |
N | 1 | 2 | 3 |
Корпус | 7mm x 7mm LQFP-48 Габаритный чертеж корпуса | 7mm x 7mm LQFP-48 Габаритный чертеж корпуса | 7mm x 7mm LQFP-48 Габаритный чертеж корпуса |
Код корпуса | LX | LX | LX |
Индекс корпуса | 05-08-1760 | 05-08-1760 | 05-08-1760 |
Количество выводов | 48 | 48 | 48 |
Parameters / Models | LTC2335CLX-18#PBF | LTC2335HLX-18#PBF | LTC2335ILX-18#PBF |
ADC INL, LSB | 1 | 1 | 1 |
ADCs | 1 | 1 | 1 |
Архитектура | SAR | SAR | SAR |
Bipolar/Unipolar Input | True Bipolar, Unipolar | True Bipolar, Unipolar | True Bipolar, Unipolar |
Bits, bits | 18 | 18 | 18 |
Количество каналов | 8 | 8 | 8 |
DNL, LSB | 0.2 | 0.2 | 0.2 |
Demo Boards | DC2412A-A | DC2412A-A | DC2412A-A |
Экспортный контроль | нет | нет | нет |
Основные особенности | SoftSpan, Programmable Sequencer | SoftSpan, Programmable Sequencer | SoftSpan, Programmable Sequencer |
I/O | Serial SPI, Serial LVDS | Serial SPI, Serial LVDS | Serial SPI, Serial LVDS |
Input Drive | Differential with wide input common mode, Single-Ended, Pseudo-Differential, Fully Differential | Differential with wide input common mode, Single-Ended, Pseudo-Differential, Fully Differential | Differential with wide input common mode, Single-Ended, Pseudo-Differential, Fully Differential |
Input Span | В±10.24V, 0V to 10.24V, В±5.12V, 0V to 5.12V В±12.5V, 0V to 12.5V, В±6.25V, 0V to 6.25V | В±10.24V, 0V to 10.24V, В±5.12V, 0V to 5.12V В±12.5V, 0V to 12.5V, В±6.25V, 0V to 6.25V | В±10.24V, 0V to 10.24V, В±5.12V, 0V to 5.12V В±12.5V, 0V to 12.5V, В±6.25V, 0V to 6.25V |
Internal Reference | да | да | да |
Рабочий диапазон температур, °C | от 0 до 70 | от -40 до 125 | от -40 до 85 |
Power, mW | 182 | 182 | 182 |
SFDR, дБ | 110 | 110 | 110 |
SINAD, дБ | 96.5 | 96.5 | 96.5 |
SNR, дБ | 96.7 | 96.7 | 96.7 |
Simultaneous | нет | нет | нет |
Speed, ksps | 1000 | 1000 | 1000 |
Диапазон напряжения питания | В±15V | В±15V | В±15V |
THD dB, дБ | -109 | -109 | -109 |
Серия: LTC2335-18 (3)
- Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Multi Channel ADCs
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) ADCs
