Datasheet Texas Instruments LM20123MHE/NOPB — Даташит
Серия | LM20123 |
Модель | LM20123MHE/NOPB |
2,95–5,5 В, 3 А, синхронный понижающий стабилизатор тока с дополнительным автомобильным классом 16-HTSSOP от -40 до 125
LM20123/LM20123Q 3A, 1.5MHz PowerWise В® Synchronous Buck Regulator datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 27 мар 2013
Купить LM20123MHE/NOPB на РадиоЛоцман.Цены — от 117 до 585 ₽ 18 предложений от 11 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 3A 16-PowerTSSOP (0.173, 4.40mm Width) | |||
LM20123MHE/NOPB Texas Instruments | 117 ₽ | ||
LM20123MHE/NOPB Texas Instruments | от 137 ₽ | ||
LM20123MHE/NOPB | по запросу | ||
LM20123MHE/NOPB Texas Instruments | по запросу |
Pin | 16 | 16 |
Package Type | PWP | PWP |
Industry STD Term | HTSSOP | HTSSOP |
Package QTY | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R |
Маркировка | 20123 | MH |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 5 | 5 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Control Mode | Current Mode |
Duty Cycle(Max) | 85 % |
Iout(Max) | 3 A |
Iq(Typ) | 3.5 мА |
Package Group | HTSSOP |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Adjustable Current Limit,Enable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking |
Switching Frequency(Max) | 1500 kHz |
Switching Frequency(Min) | 1500 kHz |
Тип | Converter |
Vin(Max) | 5.5 В |
Vin(Min) | 2.95 В |
Vout(Max) | 5 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: LM20123EVAL
3A, 1.5MHz PowerWiseВ® Synchronous Buck Regulator Evaluation Module
- AN-2077 LM20k POL Module (Rev. A)PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta - AN-1747 3A LM20k Reference Designs (Rev. A)PDF, 242 Кб, Версия: A, Файл опубликован: 3 май 2013
The LM20123, LM20133, and LM20143 are a full-featured family of high performance 3A synchronousbuck converters. These devices are tailored to operate over an input voltage range of 2.95 V to 5.5 V andeach can be optimized to meet many different performance requirements. The LM20123 operates at afixed frequency and only requires 11 components to generate a solution. The LM20143 is similar to
Серия: LM20123 (3)
- LM20123MH/NOPB LM20123MHE/NOPB LM20123MHX/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
