Источники питания Keen Side
Datasheet LTC3850-2 (Analog Devices) - 4
ОписаниеDual, 2-Phase Synchronous Step-Down Switching Controller
Страниц / Страница36 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 417 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
46 предложений от 21 поставщиков
LTC3850IGN-2#PBF
от 119 ₽
LTC3850IGN-2#PBF
157 ₽
ЧипСити
LTC3850IGN-2#TRPBF
231 ₽
ЭИК
LTC3850IGN-2#PBF
от 777 ₽
Открытие интернет-магазина MEAN WELL Market
LTC3850-2
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C, VIN = 15V, VRUN1,2 = 5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Oscillator and Phase-Locked Loop
fNOM Nominal Frequency VFREQ = 1.2V 450 500 550 kHz fLOW Lowest Frequency VFREQ = 0V 210 250 290 kHz fHIGH Highest Frequency VFREQ ≥ 2.4V 700 780 860 kHz RMODE/PLLIN MODE/PLLIN Input Resistance 250 kΩ IFREQ Phase Detector Output Current Sinking Capability fMODE < fOSC –13 μA Sourcing Capability fMODE > fOSC 13 μA
PGOOD Output
VPGL PGOOD Voltage Low IPGOOD = 2mA 0.1 0.3 V IPGOOD PGOOD Leakage Current VPGOOD = 5V ±2 μA VPG PGOOD Trip Level VFB with Respect to Set Regulated Voltage VFB Ramping Negative –5 – 7.5 –10 % VFB Ramping Positive 5 7.5 10 %
Note 1:
Note 4:
The LTC3850I-2 is tested in a feedback loop that servos VITH1,2 to may cause permanent damage to the device. Exposure to any Absolute a specifi ed voltage and measures the resultant VFB1,2. Maximum Rating condition for extended periods may affect device
Note 5:
Dynamic supply current is higher due to the gate charge being reliability and lifetime. delivered at the switching frequency. See Applications Information.
Note 2:
The LTC3850I-2 is guaranteed to meet performance specifi cations
Note 6:
Rise and fall times are measured using 10% and 90% levels. Delay over the –40°C to 85°C operating temperature range. times are measured using 50% levels.
Note 3:
T
Note 7:
The minimum on-time condition is specifi ed for an inductor J is calculated from the ambient temperature TA and power dissipation P peak-to-peak ripple current ≥40% of I D according to the following formulas: MAX (see Minimum On-Time Considerations in the Applications Information section). LTC3850IGN-2: TJ = TA + (PD • 95°C/W)
TYPICAL PERFORMANCE CHARACTERISTICS Effi ciency vs Output Current Effi ciency vs Output Current Effi ciency and Power Loss and Mode and Mode vs Input Voltage
100 100 100 2000 VIN = 12V VOUT = 3.3V 90 VOUT = 1.8V 90 BURST IOUT = 2A BURST 80 80 95 1500 POWER LOSS (mW) 70 70 EFFICIENCY 60 DCM DCM 60 50 50 90 1000 40 40 EFFICIENCY (%) POWER LOSS EFFICIENCY (%) EFFICIENCY (%) 30 30 CCM CCM 85 500 20 20 10 10 VIN = 12V VOUT = 3.3V 0 0 80 0 10 100 1000 10000 10 100 1000 10000 5 10 15 20 25 LOAD CURRENT (mA) LOAD CURRENT (mA) INPUT VOLTAGE (V) 38502 G01 38502 G02 38502 G03 CIRCUIT OF FIGURE 14 CIRCUIT OF FIGURE 14 CIRCUIT OF FIGURE 14 38502f 4
