Datasheet CPC1004N (Littelfuse) - 3
Производитель | Littelfuse |
Описание | 100V, 300mA Single-Pole Normally Open Relay |
Страниц / Страница | 6 / 3 — CPC1004N. PERFORMANCE DATA*. Typical LED Forward Voltage Drop. Typical I … |
Формат / Размер файла | PDF / 195 Кб |
Язык документа | английский |
CPC1004N. PERFORMANCE DATA*. Typical LED Forward Voltage Drop. Typical I for Switch Operation. Typical I for Switch Dropout
44 предложений от 21 поставщиков Оптическое МОП-реле, 4 выводное. Напряжение нагрузки 100 В, ток нагрузки 150 мА, максимальное сопротивление в открытом состояниии 4 Ом. |
| CPC1004NTR Clare | 67 ₽ | |
| CPC1004NTR IXYS | от 75 ₽ | |
| CPC1004NTR IXYS | от 263 ₽ | |
| CPC1004NTR
| по запросу | |
INTEGRATED CIRCUITS DIVISION
CPC1004N PERFORMANCE DATA* Typical LED Forward Voltage Drop Typical I for Switch Operation Typical I for Switch Dropout F F (N=50, I =5mA) (N=50, I =300mA) (N=50, I =300mA) F L L
30 25 25 25 20 20 20 15 15 15 10 10
vice Count (N)
10
vice Count (N) vice Count (N) De De De
5 5 5 0 0 0 1.364 1.366 1.368 1.370 1.372 0.70 0.75 0.80 0.85 0.90 0.95 1.0 0.75 0.80 0.85 0.90 0.95 1.00 1.05
LED Forward Voltage Drop (V) LED Current (mA) LED Current (mA) Typical On-Resistance Distribution Typical Turn-On Time Typical Turn-Off Time (N=50, I =2mA, I =300mA) (N=50, I =5mA, I =300mA) (N=50, I =5mA, I =200mA) F L F L F L
35 25 25 30 20 20 25 20 15 15 15 10 10
vice Count (N) vice Count (N) vice Count (N)
10
De De De
5 5 5 0 0 0 2.9 3.0 3.1 3.2 3.3 3.4 3.5 0.25 0.30 0.35 0.40 0.45 0.50 0.55 0.21 0.22 0.23 0.24 0.25 0.26 0.27
On-Resistance (
) Turn-On Time (ms) Turn-Off Time (ms) Typical Blocking Voltage Distribution (N=50)
35 30 25 20 15
vice Count (N)
10
De
5 0 106 109 112 115 118 121 124
Blocking Voltage (V ) P Typical I for Switch Operation Typical I for Switch Dropout F F Typical LED Forward Voltage Drop vs. Temperature vs. Temperature vs. Temperature (I =100mA) (I =100mA) L L
1.8 3.0 3.0 1.7
op (V)
2.5 2.5
Dr
1.6
e
I =10mA 2.0 2.0
g
1.5 F I =5mA F
olta V
1.4 I =2mA 1.5 1.5 F
d
1.3 1.0 1.0 1.2
0.5 0.5 1.1
LED Forwar
1.0 0 0 -50 -25 0 25 50 75 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100
Temperature (ºC) Temperature (ºC) Temperature (ºC)
*Unless otherwise noted, data presented in these graphs is typical of device operation at 25ºC. R10
www.ixysic.com 3
