Datasheet MAX4240, MAX4241, MAX4242, MAX4243, MAX4244 (Analog Devices) - 8
Описание | Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps |
Страниц / Страница | 16 / 8 — Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps. Typical … |
Формат / Размер файла | PDF / 2.8 Мб |
Язык документа | английский |
Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps. Typical Operating Characteristics (continued)
Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0, VCM = VCC/2, VSHDN = VCC, RL = 100kΩ to VCC/2, TA = +25°C unless otherwise noted.) OPEN-LOOP GAIN GAIN AND PHASE vs. FREQUENCY GAIN AND PHASE vs. FREQUENCY vs. TEMPERATURE (CL = 0pF) (CL = 100pF) 110 MAX4240/44-16 MAX4240/44-17 60 180 60 180 AV = +1000V/V AV = +1000V/V 105 50 144 50 144 MAX4240/44-15 VCC = +5.5V, RL TO VEE 40 108 40 108 100 30 72 30 72 95 VCC = +5.5V, RL TO VCC 20 36 20 36 90 V 10 0 10 0 GAIN (dB) CC = +1.8V, RL TO VEE GAIN (dB) GAIN (dB) 85 0 -36 0 -36 V PHASE (DEGREES) PHASE (DEGREES) CC = +1.8V, RL TO VCC -10 -72 -10 -72 80 -20 -108 -20 -108 75 -30 -144 -30 -144 70 -40 -180 -40 -180
MAX4240–MAX4244
-60 -40 -20 0 20 40 60 80 100 10 100 1k 10k 100k 10 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz) MAX4242/MAX4243/MAX4244 TOTAL HARMONIC DISTORTION PLUS NOISE
VOLTAGE NOISE
CROSSTALK vs. FREQUENCY vs. FREQUENCY
vs. FREQUENCY
-60 1 1000 RL = 10k1 / MAX4240/44-18 -70 MAX4240/44-19 √Hz) MAX4240 toc20 -80 0.1 100 GAIN (dB) -90 THD + NOISE (%) -100 VOLTAGE NOISE DENSITY (nV RL = 100k1 RL = 10k1 -110 0.01 10 10 100 1k 10k 1 10 100 1000 0.1 1 10 FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) LOAD RESISTOR vs. SMALL-SIGNAL TRANSIENT RESPONSE SMALL-SIGNAL TRANSIENT RESPONSE CAPACITIVE LOAD (NONINVERTING) (INVERTING) 1000 MAX4240/44-22 MAX4240/44-23 10% OVERSHOOT 100mV 100mV MAX4240/44-21 MAX4240/44-20 IN REGION OF IN ) MARGINAL STABILITY 1 0V 0V (k 100 0mV/div 50mV/div R LOAD 100mV 100mV REGION OF OUT OUT STABLE OPERATION 0V 0V 10 0 250 500 750 1000 10μs/div 10μs/div CLOAD (pF)
8 _______________________________________________________________________________________
