Datasheet ADG1611, ADG1612, ADG1613 (Analog Devices) - 4
Описание1 Ω Typical On Resistance, ±5 V, +12 V, +5 V, and +3.3 V Quad SPST Switches
Страниц / Страница16 / 4 — ADG1611/ADG1612/ADG1613. Data Sheet. 12 V SINGLE SUPPLY. Table 2. −40°C …
ВерсияC
Формат / Размер файлаPDF / 489 Кб
ADG1611/ADG1612/ADG1613. Data Sheet. 12 V SINGLE SUPPLY. Table 2. −40°C to −40°C to. Parameter. 25°C +85°C. +125°C. Unit
ADG1611/ADG1612/ADG1613 Data Sheet 12 V SINGLE SUPPLY Table 2 −40°C to −40°C to Parameter 25°C +85°C +125°C Unit
37 предложений от 17 поставщиков
Микросхема Чип аналогового переключателя, Analogue Switch, Quad Channel, SPST, 4Channels, 1.1Ω, 3.3V to 16V, ± 3.3V to ± 8V, LFCSP
ADG1611BCPZ-REEL7
от 99 ₽
ADG1611BCPZ-REEL7
142 ₽
ADG1611BCPZ-REEL7
ADG1611BCPZ-REEL7
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 13 link to page 13 link to page 14 link to page 13
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 0.95 Ω typ VS = 0 V to 10 V, IS = −10 mA; see Figure 24 1.1 1.25 1.45 Ω max VDD = 10.8 V, VSS = 0 V On Resistance Match Between Channels (∆RON) 0.03 Ω typ VS = 0 V to 10 V, IS = −10 mA 0.06 0.7 0.08 Ω max On Resistance Flatness (RFLAT(ON)) 0.2 Ω typ VS = 0 V to 10 V, IS = −10 mA 0.23 0.27 0.32 Ω max LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.1 nA typ VS = 1 V/10 V, VS = 10 V/1 V, see Figure 25 ±0.3 ±1 ±6 nA max Drain Off Leakage, ID (Off) ±0.1 nA typ VS = 1 V/10 V, VS = 10 V/1 V see Figure 25 ±0.3 ±1 ±6 nA max Channel On Leakage, ID, IS (On) ±0.2 nA typ VS = VD = 1 V or 10 V; see Figure 26 ±0.4 ±1.5 ±10 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 5 pF typ DYNAMIC CHARACTERISTICS1 tON 125 ns typ RL = 300 Ω, CL = 35 pF 156 190 215 ns max VS = 8 V; see Figure 31 tOFF 75 ns typ RL = 300 Ω, CL = 35 pF 87 93 99 ns max VS = 8 V; see Figure 31 Break-Before-Make Time Delay, tD (ADG1613 35 ns typ RL = 300 Ω, CL = 35 pF Only) 30 ns min VS1 = VS2 = 8 V; see Figure 32 Charge Injection 170 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; see Figure 33 Off Isolation 70 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 27 Channel-to-Channel Crosstalk 110 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 28 Total Harmonic Distortion + Noise 0.012 % typ RL = 110 Ω, 5 V p-p, f = 20 Hz to 20 kHz; see Figure 30 −3 dB Bandwidth 38 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 29 CS (Off) 60 pF typ VS = 6 V, f = 1 MHz CD (Off) 60 pF typ VS = 6 V, f = 1 MHz CD, CS (On) 154 pF typ VS = 6 V, f = 1 MHz POWER REQUIREMENTS VDD = 12 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1 µA max IDD 320 µA typ Digital inputs = 5 V 480 µA max VDD 3.3/16 V min/max 1 Guaranteed by design, not subject to production test. Rev. C | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
