Источники питания Keen Side
Datasheet ADG798-KGD (Analog Devices) - 5
ОписаниеHigh Temperature, Low Voltage, 8-Channel Multiplexer
Страниц / Страница13 / 5 — Known Good Die. ADG798-KGD. DUAL SUPPLY. Table 3. −55°C. TA ≤ +175°C. …
Формат / Размер файлаPDF / 822 Кб
Known Good Die. ADG798-KGD. DUAL SUPPLY. Table 3. −55°C. TA ≤ +175°C. −55°C ≤ TA ≤ +210°C. Parameter. Symbol. Test Conditions/Comments. Min
Known Good Die ADG798-KGD DUAL SUPPLY Table 3 −55°C TA ≤ +175°C −55°C ≤ TA ≤ +210°C Parameter Symbol Test Conditions/Comments Min
16 предложений от 10 поставщиков
Akcel
ADG798HFRZ
от 10 820 ₽
ЧипСити
ADG798HFRZ
25 501 ₽
ЭИК
ADG798HFRZ
от 34 963 ₽
T-electron
ADG798HFRZ
1 611 324 ₽
link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12
VDD = 2.5 V ± 10%, VSS = −2.5 V ± 10%, GND = 0 V, unless otherwise noted.
Table 3. −55°C TA ≤ +175°C −55°C ≤ TA ≤ +210°C Parameter Symbol Test Conditions/Comments Min Typ1 Max Min Typ1 Max Unit
ANALOG SWITCH Analog Signal Range VSS VDD VSS VDD V On Resistance RON VS = VSS to VDD, IDS = 10 mA, 4.5 9 5 10 Ω see Figure 3 Matching Between Channels ΔRON VS = VSS to VDD, IDS = 10 mA 0.6 1.2 1.25 1.5 Ω Flatness RFLAT (ON) VS = VSS to VDD, IDS = 10 mA 0.5 1.5 0.6 2 Ω LEAKAGE CURRENTS VDD = +2.75 V, VS = −2.75 V Source Off Leakage IS (Off) VS = +2.25 V/−1.25 V, −50 ±0.01 +50 −180 ±0.01 +180 nA VD = −1.25 V/+2.25 V, see Figure 4 Drain Off Leakage ID (Off ) VS = +2.25 V/−1.25 V, −650 ±0.01 +650 −2600 ±0.01 +2600 nA VD = −1.25 V/+2.25 V, see Figure 5 Channel On Leakage ID, IS (On) VD = VS = −1.25 V/+2.25 V, −650 ±0.01 +650 −2600 ±0.01 +2600 nA see Figure 6 DIGITAL INPUTS Input Voltage High VINH 1.7 1.7 V Low VINL 0.7 0.7 V Input Current IINL or IINH VIN = VINL or VINH −800 +0.005 +800 −800 +0.005 +800 nA Digital Input Capacitance CIN 2 2 pF DYNAMIC CHARACTERISTICS Transition Time tTRANSITION RL = 150 Ω, CL = 15 pF, 18 28 18 30 ns see Figure 7, VS1 = 1.5 V/0 V, VS8 = 0 V/1.5 V Break-Before-Make Time Delay tOPEN RL = 150 Ω, CL = 15 pF, 1 10 1 10 ns VS = 2 V, see Figure 8 TA = maximum temperature 13 13 ns On Time tON (EN) RL = 150 Ω, CL = 15 pF, 19 28 19 30 ns VS = 2 V, see Figure 9 Off Time tOFF (EN) RL = 150 Ω, CL = 15 pF, 11.5 19 11.5 20 ns VS = 2 V, see Figure 9 Charge Injection QINJ VS = 0 V, RS = 0 Ω, CL = 1 nF, ±3 ±3 pC see Figure 10 Off Isolation RL = 50 Ω, CL = 5 pF, f = 10 MHz −60 −60 dB RL = 50 Ω, CL = 5 pF, −80 −80 dB f = 1 MHz, see Figure 11 Channel to Channel Crosstalk RL = 50 Ω, CL = 5 pF, f = 10 MHz −60 −60 dB RL = 50 Ω, CL = 5 pF, −80 −80 dB f = 1 MHz, see Figure 12 −3 dB Bandwidth RL = 50 Ω, CL = 5 pF, see Figure 13 55 55 MHz Source Capacitance, Off CS (Off ) f = 1 MHz 13 13 pF Drain Capacitance, Off CD (Off ) f = 1 MHz 85 85 pF Source/Drain Capacitance, On CD, CS (On) f = 1 MHz 96 96 pF POWER REQUIREMENTS Supply Current IDD VDD = 2.75 V, 5 35 40 70 μA digital inputs = 0 V or 2.75 V ISS VSS = −2.75 V, 5 35 40 70 μA digital inputs = 0 V or 2.75 V 1 TA = 25°C, except for the analog switch and power requirements values where TA = 175°C or 210°C. Rev. 0 | Page 5 of 13 Document Outline FEATURES APPLICATIONS METAL MASK DIE IMAGE GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY CONTINUOUS CURRENT PER CHANNEL, Sx OR D PEAK CURRENT PER CHANNEL, Sx OR D (PULSED AT 1 MS, 10% DUTY CYCLE MAXIMUM) ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TRUTH TABLE TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
