Datasheet N-Channel 60-V (D-S) MOSFET (Vishay) - 5
ПроизводительVishay
ОписаниеP-Channel 80 V (D-S) MOSFET
Страниц / Страница10 / 5 — Si2337DS. TYPICAL CHARACTERISTICS. Current Derating a. Power Derating. …
Формат / Размер файлаPDF / 226 Кб
Si2337DS. TYPICAL CHARACTERISTICS. Current Derating a. Power Derating. Single Pulse Avalanche Capability. Note
Si2337DS TYPICAL CHARACTERISTICS Current Derating a Power Derating Single Pulse Avalanche Capability Note
53 предложений от 21 поставщиков
Силовой МОП-транзистор, P Канал, 80 В, 2.2 А, 0.216 Ом, TO-236, Surface Mount
SI2337DS-T1-E3
от 37 ₽
ЧипСити
SI2337DS-T1-E3
61 ₽
SI2337DS-T1-E3
от 85 ₽
SI2337DS-T1-E3
от 139 ₽
Si2337DS
www.vishay.com Vishay Siliconix
(25 °C, unless otherwise noted) 2.8 2.5 2.4 2.0 ) 2.0 A( tner 1.5 r 1.6 u C r (W) e ni w ar 1.2 o P D 1.0 - I D 0.8 0.5 0.4 0.0 0.0 0 25 50 75 100 125 150 25 50 75 100 125 150 TC - Case Temperature (°C) TC - Case Temperature (°C)
10 ) A( tnerruC ehcnalavA kaeP - LI I C T A A BV - VDD 1 1.0E-6 10.0E-6 100.0E-6 1.0E-3 10.0E-3 TA - Time In Avalanche (s)
a. The power dissipation PD is based on TJ max. = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit S19-0386-Rev. F, 20-May-2019
5
Document Number: 73533 For technical questions, contact: [email protected] THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
