Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet L99VR01 (STMicroelectronics) - 5
ПроизводительSTMicroelectronics
ОписаниеAutomotive Linear Voltage Regulator with Configurable Output Voltage having 200mA current capability
Страниц / Страница47 / 5 — L99VR01. Block diagram and pins description. PowerSSO-12. Pin name. SO-8 …
Формат / Размер файлаPDF / 3.9 Мб
L99VR01. Block diagram and pins description. PowerSSO-12. Pin name. SO-8 pin. Function. pin. Figure 3. Pins configuration. DS13649. Rev 2
L99VR01 Block diagram and pins description PowerSSO-12 Pin name SO-8 pin Function pin Figure 3 Pins configuration DS13649 Rev 2
24 предложений от 8 поставщиков
IC REG LIN POS PROG 200MA 8SO
L99VR01STR
67 ₽
L99VR01STR
74 ₽
Зенер
Россия и страны ТС
L99VR01STR
от 119 ₽
LIXINC Electronics
L99VR01STR
от 375 ₽
Watchdog refresh input. Wi 10 If the square wave frequency at this input pin is too low, a low pulse at RST pin is generated (just for L99VR01J). Reset output. RST 7 11 It is pulled down when output voltage goes below Vo_th or frequency at Wi is too low (just for L99VR01J). Leave floating if not used. Voltage regulator output. VO 8 12 Block to ground with a capacitor ≥ 3.3 µF (needed for regulator stability). TAB TAB Connected to ground
SO-8 PowerSSO-12
DS13649
Rev 2 page 5/47
Document Outline Cover image Product status link / summary Features Description 1 Block diagram and pins description 2 Electrical specifications 2.1 Absolute maximum ratings 2.2 Thermal data 2.2.1 Thermal resistance 2.2.2 Thermal protection 2.3 Electrical characteristics 2.4 Electrical characteristics curves 3 Test circuit and waveforms plot 3.1 Load regulation 4 Application information 4.1 Voltage regulator 4.2 Output current limitation 4.3 Output voltage selection 4.4 Enable 4.5 Reset 4.6 Autonomous watchdog 4.7 Thermal warning and thermal shutdown 4.8 Overvoltage detection by advanced thermal warning read-out 4.9 Fast output discharge 4.10 Undervoltage lockout UVLO 4.11 Functional safety management 5 Application 6 Package and PCB thermal data 6.1 PowerSSO-12 Thermal data 6.2 SO-8 thermal data 7 Package information 7.1 PowerSSO-12 package information 7.2 SO-8 package information 7.3 PowerSSO-12 packaging information 7.4 SO-8 packaging information 8 Order codes Revision history Contents List of tables List of figures
