Клеммные колодки Keen Side
Datasheet ADL5513 (Analog Devices) - 9
Описание1 MHz to 4 GHz, 80 dB Logarithmic Detector/Controller
Страниц / Страница25 / 9 — Data Sheet. ADL5513. TYPICAL PERFORMANCE CHARACTERISTICS. 2.4. 3.0. 2.2. …
ВерсияA
Data Sheet. ADL5513. TYPICAL PERFORMANCE CHARACTERISTICS. 2.4. 3.0. 2.2. 2.5. 2.0. 1.8. 1.5. 1.6. 1.0. 1.4. 0.5. (V). 1.2. R (. –0.5. RRO. 0.8. –1.0. +25°C. 0.6
Data Sheet ADL5513 TYPICAL PERFORMANCE CHARACTERISTICS 2.4 3.0 2.2 2.5 2.0 1.8 1.5 1.6 1.0 1.4 0.5 (V) 1.2 R ( –0.5 RRO 0.8 –1.0 +25°C 0.6
6 предложений от 6 поставщиков
Радиочастотная деталь RF, 1MHz to 4GHz, 80dB Logarithmic Detector/Controller
ADL5513ACPZ-WP
65 ₽
ADL5513ACPZ-WP
865 ₽
LifeElectronics
ADL5513ACPZ-WP
ADL5513ACPZ-WP
VPOS = 5 V; TA = +25°C, −40°C, +85°C, +125°C; CLPF = 0.1 μF, error is calculated by using the best-fit line between PIN = −20 dBm and PIN = −40 dBm at the specified input frequency, unless otherwise noted.
2.4 3.0 2.4 3.0 2.2 2.5 2.2 2.5 2.0 2.0 2.0 2.0 1.8 1.5 1.8 1.5 1.6 1.0 1.6 1.0 1.4 0.5 B) B) d 1.4 0.5 d (V) (V) 1.2 0 R ( 1.2 0 R ( UT UT O O V 1.0 –0.5 RRO V 1.0 –0.5 RRO E E 0.8 –1.0 0.8 –1.0 +25°C 0.6 –1.5 +25°C 0.6 –1.5 –40°C –40°C 0.4 –2.0 0.4 +85°C –2.0 +85°C +125°C 0.2 +125°C –2.5 0.2 –2.5 0 –3.0 0 –3.0 –70 –60 –50 –40 –30 –20 –10 0 10
003
005
PIN (dBm) P
07514-
IN (dBm)
07514- Figure 3. VOUT and Log Conformance vs. Input Amplitude at 100 MHz, Figure 6. VOUT and Log Conformance vs. Input Amplitude at 100 MHz, Typical Device, VTADJ = 0.89 V Multiple Devices, VTADJ = 0.89 V
2.4 3.0 2.4 3.0 2.2 2.5 2.2 2.5 2.0 2.0 2.0 2.0 1.8 1.5 1.8 1.5 1.6 1.0 1.6 1.0 1.4 0.5 B) B) d 1.4 0.5 d (V) (V) 1.2 0 R ( 1.2 0 R ( UT UT O O V 1.0 –0.5 RRO V 1.0 –0.5 RRO E E 0.8 –1.0 0.8 –1.0 +25°C 0.6 +25°C –1.5 0.6 –1.5 –40°C –40°C +85°C 0.4 –2.0 0.4 –2.0 +85°C +125°C 0.2 +125°C –2.5 0.2 –2.5 0 –3.0 0 –3.0 –70 –60 –50 –40 –30 –20 –10 0 10
004
006
PIN (dBm) P
07514-
IN (dBm)
07514- Figure 4. VOUT and Log Conformance vs. Input Amplitude at 900 MHz, Figure 7. VOUT and Log Conformance vs. Input Amplitude at 900 MHz, Typical Device, VTADJ = 0.86 V Multiple Devices, VTADJ = 0.86 V
2.4 3.0 2.4 3.0 2.2 2.5 2.2 2.5 2.0 2.0 2.0 2.0 1.8 1.5 1.8 1.5 1.6 1.0 1.6 1.0 1.4 0.5 B) B) d 1.4 0.5 d (V) (V) 1.2 0 R ( 1.2 0 R ( UT UT O O V 1.0 –0.5 RRO V 1.0 –0.5 RRO E E 0.8 –1.0 0.8 –1.0 +25°C 0.6 +25°C –1.5 0.6 –1.5 –40°C –40°C 0.4 –2.0 0.4 +85°C –2.0 +85°C 125°C 0.2 +125°C –2.5 0.2 –2.5 0 –3.0 0 –3.0 –70 –60 –50 –40 –30 –20 –10 0 10
007
010
PIN (dBm) P
07514-
IN (dBm)
07514- Figure 5. VOUT and Log Conformance vs. Input Amplitude at 1900 MHz, Figure 8. VOUT and Log Conformance vs. Input Amplitude at 1900 MHz, Typical Device, VTADJ = 0.80 V Multiple Devices, VTADJ = 0.80 V Rev. A | Page 9 of 25 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Input Signal Coupling Output Filtering Output Interface Setpoint Interface Description of Characterization Error Calculations Adjusting Accuracy Through Choice of Calibration Points Temperature Compensation of Output Voltage Device Calibration Power-Down Functionality Measurement Mode Setting the Output Slope in Measurement Mode Controller Mode Constant Power Operation Increasing the Dynamic Range of the ADL5513 Evaluation Board Outline Dimensions Ordering Guide
