Datasheet HMC414MS8G, 414MS8GE (Analog Devices) - 7
ОписаниеGaAs InGaP HBT MMIC POWER AMPLIFIER, 2.2 - 2.8 GHz
Страниц / Страница8 / 7 — HMC414MS8G / 414MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 2.2 - 2.8 …
Формат / Размер файлаPDF / 383 Кб
HMC414MS8G / 414MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 2.2 - 2.8 GHz. Evaluation PCB
HMC414MS8G / 414MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 2.2 - 2.8 GHz Evaluation PCB
29 предложений от 13 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC414MS8GE
12 ₽
IC Home
HMC414MS8GE
995 ₽
HMC414MS8GE
1 462 ₽
727GS
HMC414MS8GE
v04.0607
11 T - SM S R IE IF L P M * For 5V operation on Vctl line, select R1, R2 such that 3.6V is R A presented on Pins 6 and 8. E W O & P R A
List of Materials for Evaluation PCB 105006 [1]
E The circuit board used in the fi nal application should Item Description IN use RF circuit design techniques. Signal lines J1 - J2 PCB Mount SMA RF Connector L should have 50 ohm impedance while the package J3 2 mm DC Header ground leads and exposed paddle should be con- C1 2.7 pF Capacitor, 0603 Pkg. nected directly to the ground plane similar to that C2 100 pF Capacitor, 0402 Pkg. shown. A sufficient number of via holes should be C3 - C6 330 pF Capacitor, 0603 Pkg. used to connect the top and bottom ground planes. C7 2.2 μF Capacitor, Tantalum The evaluation board should be mounted to an L1 18nH Inductor 0603 Pkg. appropriate heat sink. The evaluation circuit board HMC414MS8G / HMC414MS8GE U1 Amplifi er shown is available from Hittite upon request. PCB [2] 105074 Eval Board [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 64
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
