Datasheet HMC453QS16G, 453QS16GE (Analog Devices) - 5
ОписаниеInGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz
Страниц / Страница22 / 5 — HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 …
HMC453QS16G / 453QS16GE. InGaP HBT 1.6 WATT POWER. AMPLIFIER, 0.4 - 2.2 GHz. Noise Figure. Output IP3 vs. Temperature @ 470 MHz
HMC453QS16G / 453QS16GE InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs Temperature @ 470 MHz
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC453QS16GETR
56 ₽
HMC453QS16GETR
953 ₽
ЧипСити
HMC453QS16GETR
979 ₽
HMC453QS16GETR
Hittite
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
v01.0205
InGaP HBT 1.6 WATT POWER AMPLIFIER, 0.4 - 2.2 GHz Noise Figure Output IP3 vs. Temperature @ 470 MHz vs. Temperature @ 470 MHz
58 10 56 9 54 8 52 7 50 6 48 GURE (dB) 5 11 46 +25C OIP3 (dBm) 4 +85C 44 SE FI +25C 3 -40C 42 +85C NOI 40 -40C 2 T 38 1 36 0 0.43 0.45 0.47 0.49 0.51 0.53 0.43 0.45 0.47 0.49 0.51 0.53 FREQUENCY (GHz) FREQUENCY (GHz) - SM S
Reverse Isolation Gain, Power & IP3 vs. Temperature @ 470 MHz vs. Supply Voltage @ 470 MHz
0 55 50 -5 45 Gain PLIFIER P1dB -10 40 Psat M +25C OIP3 +85C 35 -15 -40C Psat (dBm), OIP3 (dBm) 30 ISOLATION (dB) -20 25 ER A 20 -25 W 15 O -30 10 0.43 0.45 0.47 0.49 0.51 0.53 4.5 4.75 5 5.25 5.5 GAIN (dB), P1dB (dBm), FREQUENCY (GHz) Vs (Vdc) & P R
ACPR vs. Supply Voltage @ 470 MHz
A
Power Compression @ 470 MHz W-CDMA, 64 DPCH
E 55 -10 50 -15 Pout LIN 45 Gain -20 W-CDMA 40 PAE -25 Frequency: 470 MHz -30 Integration BW: 3.84 MHz 35 64 DPCH -35 30 -40 25 4.5V -45 5V 20 ACPR (dBc) 5.5V -50 15 -55 10 Pout (dBm), Gain (dB), PAE (%) -60 5 -65 Source ACPR 0 -70 -10 -8 -6 -4 -2 0 2 4 6 8 10 12 14 8 10 12 14 16 18 20 22 24 26 28 INPUT POWER (dBm) Channel Power (dBm) Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 182
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
