Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet HMC1040LP3CE (Analog Devices) - 3
ОписаниеGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 24 - 43.5 GHz
Страниц / Страница6 / 3 — HMC1040LP3CE. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 24 - 43.5 GHz. P1dB …
Формат / Размер файлаPDF / 591 Кб
HMC1040LP3CE. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 24 - 43.5 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC1040LP3CE GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 24 - 43.5 GHz P1dB vs Temperature Psat vs Temperature
19 предложений от 12 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
ЧипСити
HMC1040LP3CE
2 777 ₽
HMC1040LP3CE
Maxim
3 587 ₽
Элитан
HMC1040LP3CE
10 690 ₽
Зенер
Россия и страны ТС
HMC1040LP3CE
от 12 398 ₽
HMC1040LP3CE
v00.0112
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 24 - 43.5 GHz P1dB vs. Temperature Psat vs. Temperature
17 17 T 15 m 15 s 13 13 (dBm) 11 (dBm) e - +25C P1dB Psat 11 +85C +25C -40C is 9 +85C -40C o 9 7 5 7 w N 19 22 25 28 31 34 37 40 43 46 19 22 25 28 31 34 37 40 43 46 FREQUENCY (GHz) FREQUENCY (GHz) lo s -
Reverse Isolation vs. Temperature Power Compression @ 25 GHz
r 0 30 ie -10 (%) 25 ) -20 PAE lif +25C 20 +85C Pout p (dB N -30 -40C (dB), Gain IO PAE 15 m T LA -40 GAIN A O IS 10 -50 (dBm), -60 5 Pout -70 0 18 21 24 27 30 33 36 39 42 45 -15 -14 -13 -12 -11 -10 -9 -8 -7 -6 -5 FREQUENCY (GHz) INPUT POWER (dBm)
Power Compression @ 33 GHz Power Compression @ 42 GHz
30 30 Pout Pout (%) 25 Gain (%) 25 Gain PAE PAE PAE PAE 20 20 (dB), (dB), 15 15 GAIN GAIN 10 10 (dBm), (dBm), 5 Pout 5 Pout 0 0 -15 -14 -13 -12 -11 -10 -9 -8 -7 -6 -5 -4 -3 -2 -15 -12 -9 -6 -3 0 INPUT POWER (dBm) INPUT POWER (dBm) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
