Datasheet ADL5321 (Analog Devices) - 4
Описание2.3 GHz TO 4.0 GHz ¼ Watt RF Driver Amplifier
Страниц / Страница16 / 4 — ADL5321. Data Sheet. TYPICAL SCATTERING PARAMETERS. Table 2. Frequency. …
ВерсияD
Формат / Размер файлаPDF / 464 Кб
ADL5321. Data Sheet. TYPICAL SCATTERING PARAMETERS. Table 2. Frequency. S11. S21. S12. S22. (MHz)
ADL5321 Data Sheet TYPICAL SCATTERING PARAMETERS Table 2 Frequency S11 S21 S12 S22 (MHz)
21 предложений от 15 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
ADL5321ARKZ-R7
211 ₽
727GS
ADL5321ARKZ-R7
от 226 ₽
Зенер
Россия и страны ТС
ADL5321ARKZ-R7
от 528 ₽
ADL5321ARKZ-R7
от 1 110 ₽
VCC = 5 V and TA = 25°C; the effects of the test fixture have been de-embedded up to the pins of the device.
Table 2. Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
2400 −4.54 129.60 11.90 21.92 −26.72 −33.83 −8.18 −166.39 2450 −4.65 126.65 11.89 18.30 -26.63 −36.64 −8.27 −169.02 2500 −4.79 123.62 11.88 14.57 -26.55 −39.62 −8.37 −171.83 2550 −4.92 120.44 11.87 10.68 −26.48 −42.70 −8.45 −175.32 2600 −5.04 117.31 11.85 6.80 −26.42 −45.95 −8.44 −179.11 2650 −5.17 114.43 11.83 2.90 −26.37 −49.25 −8.39 177.31 2700 −5.33 111.78 11.80 −1.06 −26.34 −52.65 −8.33 173.43 2750 −5.50 109.21 11.77 −5.17 −26.31 −56.16 −8.15 169.22 2800 −5.70 106.84 11.74 −9.36 −26.30 −59.84 −7.90 165.46 2850 −5.94 104.85 11.71 −13.64 −26.30 −63.64 −7.63 161.87 2900 −6.25 103.23 11.66 −18.05 −26.31 −67.63 −7.31 158.01 2950 −6.61 101.91 11.62 −22.58 −26.34 −71.77 −6.88 154.58 3000 −7.03 101.06 11.56 −27.18 −26.37 −76.13 −6.44 151.64 3050 −7.53 100.92 11.50 −31.98 −26.44 −80.76 −6.00 148.53 3100 −8.12 101.82 11.40 −36.95 −26.55 −85.61 −5.53 145.65 3150 −8.78 104.04 11.29 −42.09 −26.68 −90.69 −5.03 143.14 3200 −9.47 107.91 11.15 −47.34 −26.85 −95.96 −4.56 140.74 3250 −10.07 113.72 10.97 −52.74 −27.06 −101.50 −4.08 138.36 3300 −10.45 121.55 10.76 −58.29 −27.32 −107.30 −3.61 136.16 3350 −10.45 130.87 10.49 −63.95 −27.65 −113.32 −3.19 133.97 3400 −10.02 140.04 10.17 −69.56 −28.05 −119.45 −2.80 131.77 3450 −9.25 147.61 9.80 −75.16 −28.49 −125.70 −2.43 129.85 3500 −8.28 153.06 9.39 −80.70 −29.00 −132.04 −2.13 128.08 3550 −7.27 156.76 8.92 −86.04 −29.58 −138.45 −1.89 126.22 3600 −6.34 159.01 8.39 −91.20 −30.20 −144.79 −1.66 124.51 3650 −5.51 160.11 7.83 −96.07 −30.88 −151.12 −1.48 123.23 3700 −4.78 160.43 7.26 −100.64 −31.57 −157.36 −1.37 122.16 3750 −4.14 160.36 6.66 −104.97 −32.29 −163.69 −1.27 121.07 3800 −3.60 160.07 6.04 −108.96 −33.02 −170.01 −1.19 120.25 3850 −3.16 159.62 5.43 −112.61 −33.74 −176.34 −1.14 119.79 3900 −2.78 158.95 4.82 −116.07 −34.44 177.21 −1.12 119.31 3950 −2.45 158.24 4.20 −119.27 −35.12 170.60 −1.10 118.94 4000 −2.17 157.64 3.60 −122.18 −35.74 163.89 −1.09 118.86 Rev. D | Page 4 of 16 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics High Temperature and 3.3 V Operation Basic Layout Connections Soldering Information and Recommended PCB Land Pattern Matching Procedure WiMax Operation Evaluation Board Outline Dimensions Ordering Guide
