Datasheet ADL5604 (Analog Devices) - 4
Описание700 MHz TO 2700 MHz 1 W RF Driver Amplifier
Страниц / Страница23 / 4 — ADL5604. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
ВерсияC
Формат / Размер файлаPDF / 672 Кб
ADL5604. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADL5604 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
25 предложений от 12 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
ADL5604ACPZ-R7
Maxim
635 ₽
ADL5604ACPZ-R7
Maxim
721 ₽
T-electron
ADL5604ACPZ-R7
2 162 ₽
ADL5604ACPZ-R7
FREQUENCY = 2630 MHz Gain2 12.2 dB vs. Frequency ±60 MHz 4.8 dB Output 1 dB Compression Point 29.1 dBm Output Third-Order Intercept ∆f = 1 MHz, POUT = 14 dBm per tone 42.2 dBm Noise Figure 4.6 dB POWER INTERFACE Pin RFOUT Supply Voltage 4.75 5 5.25 V Supply Current 318 345 mA vs. Temperature −40°C ≤ TA ≤ +85°C ±7 mA POWER DOWN INTERFACE Turn-On Time 50% of control pulse to 50% of RFOUT 50 ns Turn-Off Time 50% of control pulse to 50% of RFOUT 50 ns 1 VCC1 is the supply voltage to the ADL5604 through the RFOUT pins. 2 Guaranteed maximum and minimum specified limits on this parameter are based on 6 sigma calculations. Rev. C | Page 4 of 23 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Basic Layout Connections Power Supply RF Input Interface RF Output Interface Power-Down Circuit ADL5604 Match ACPR and EVM Thermal Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
