Клеммные колодки Keen Side
Datasheet AD8628, AD8629, AD8630 (Analog Devices) - 6
ОписаниеZero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifier
Страниц / Страница24 / 6 — AD8628/. AD8629/. AD8630. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. …
ВерсияL
Формат / Размер файлаPDF / 338 Кб
AD8628/. AD8629/. AD8630. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL CHARACTERISTICS. Parameter Rating. Table 4
AD8628/ AD8629/ AD8630 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL CHARACTERISTICS Parameter Rating Table 4
Микросхема Буферный усилитель, Op Amp Single GP R-R I/O ±2.5V/5V Automotive 5Pin TSOT T/R
T-electron
AD8628WAUJZ-RL
141 ₽
AD8628WAUJZ-RL
154 ₽
AD8628WAUJZ-RL
169 ₽
IC Home
AD8628WAUJZ-RL
169 ₽
AD8628/ AD8629/ AD8630 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL CHARACTERISTICS Parameter Rating
θJA is specified for worst-case conditions, that is, θJA is specified Supply Voltage 6 V for the device soldered in a circuit board for surface-mount Input Voltage GND – 0.3 V to VS + 0.3 V packages. This was measured using a standard two-layer board. Differential Input Voltage1 ±5.0 V
Table 4.
Output Short-Circuit Duration to GND Indefinite
Package Type θ
Storage Temperature Range −65°C to +150°C
JA θJC Unit
Operating Temperature Range −40°C to +125°C 5-Lead TSOT (UJ-5) 207 61 °C/W Junction Temperature Range −65°C to +150°C 5-Lead SOT-23 (RJ-5) 230 146 °C/W Lead Temperature (Soldering, 60 sec) 300°C 8-Lead SOIC_N (R-8) 158 43 °C/W ESD AD8628 8-Lead MSOP (RM-8) 190 44 °C/W HBM 8-Lead SOIC ±7000V 14-Lead SOIC_N (R-14) 105 43 °C/W FICDM 8-Lead SOIC ±1500V 14-Lead TSSOP (RU-14) 148 23 °C/W FICDM 5-Lead TSOT ±1000V MM 8-Lead SOIC ±200V
ESD CAUTION
ESD AD8629 HBM 8-Lead SOIC ±4000V FICDM 8-Lead SOIC ±1000V ESD AD8630 HBM 14-Lead SOIC ±5000V FICDM 14-Lead SOIC ±1500V FICDM 14-Lead TSSOP ±1500V MM 14-Lead SOIC ±200V 1 Differential input voltage is limited to ±5 V or the supply voltage, whichever is less. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. L | Page 6 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—VS = 5.0 V ELECTRICAL CHARACTERISTICS—VS = 2.7 V ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION 1/f NOISE PEAK-TO-PEAK NOISE NOISE BEHAVIOR WITH FIRST-ORDER, LOW-PASS FILTER TOTAL INTEGRATED INPUT-REFERRED NOISE FOR FIRST-ORDER FILTER INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL OVERLOAD RECOVERY TIME INFRARED SENSORS PRECISION CURRENT SHUNT SENSOR OUTPUT AMPLIFIER FOR HIGH PRECISION DACS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
