Источники питания Keen Side
Datasheet AUIRL7732S2TR, AUIRL7732S2TR1 (International Rectifier) - 10
ПроизводительInternational Rectifier
ОписаниеAutomotive Grade. DirectFET Power MOSFET
Страниц / Страница11 / 10 — REEL DIMENSIONS. (QTY 4800). (QTY 1000)
Формат / Размер файлаPDF / 221 Кб
REEL DIMENSIONS (QTY 4800) (QTY 1000)
A 40V Automotive Grade Single N-Channel HEXFET Power MOSFET in a DirectFET SC package rated at 58 amperes optimized with low...
AUIRF7732S2TR1
Infineon
109 ₽
ЧипСити
AUIRF7732S2TR1
173 ₽
AUIRF7732S2TR1
185 ₽
ТаймЧипс
AUIRF7732S2TR1
AUIRL7732S2TR/TR1 Automotive DirectFET® Tape & Reel Dimension (Showing component orientation). F D LOADED TAPE FEED DIRECTION B A H C B E A G D C F H E G NOTE: Controlling dimensions in mm Std reel quantity is 4800 parts. (ordered as AUIRL7732S2TR). For 1000 parts on 7" reel, order AUIRL7732S2TR1 DIMENSIONS
REEL DIMENSIONS
STANDARD OPTION
(QTY 4800)
TR1 OPTION
(QTY 1000)
METRIC IMPERIAL NOTE: CONTROLLING METRIC IMPERIAL METRIC IMPERIAL DIMENSIONS IN MM CODE MIN MAX MIN MAX CODE MIN MAX MIN MAX MIN MAX MIN MAX A 7.90 8.10 0.311 0.319 A 330.0 N.C 12.992 N.C 177.77 N.C 6.9 N.C B 3.90 4.10 0.154 0.161 B 20.2 N.C 0.795 N.C 19.06 N.C 0.75 N.C C 11.90 12.30 0.469 0.484 C 12.8 13.2 0.504 0.520 13.5 12.8 0.53 0.50 D 5.45 5.55 0.215 0.219 D 1.5 N.C 0.059 N.C 1.5 N.C 0.059 N.C E 4.00 4.20 0.158 0.165 E 100.0 N.C 3.937 N.C 58.72 N.C 2.31 N.C F 5.00 5.20 0.197 0.205 F N.C 18.4 N.C 0.724 N.C 13.50 N.C 0.53 G 1.50 N.C 0.059 G N.C 12.4 14.4 0.488 0.567 11.9 12.01 0.47 N.C H 11.9 H 15.4 0.469 0.606 11.9 12.01 0.47 N.C 1.50 1.60 0.059 0.063 Notes: † Starting TJ = 25°C, L = 0.075mH, RG = 50Ω, IAS = 35A,Vgs = 16V.  Click on this section to link to the appropriate technical paper. ‡ Pulse width ≤ 400μs; duty cycle ≤ 2%. ‚ Click on this section to link to the DirectFET Website. ˆ Used double sided cooling, mounting pad with large heatsink. ƒ Surface mounted on 1 in. square Cu board, steady state. ‰ Mounted on minimum footprint full size board with metalized „ T back and with small clip heatsink. C measured with thermocouple mounted to top (Drain) of part. … Repetitive rating; pulse width limited by max. junction temperature. Š Rθ is measured at TJ of approximately 90°C. 10 www.irf.com
