Datasheet ADP1874, ADP1875 (Analog Devices) - 2
ОписаниеSynchronous Buck Controller with Constant On-Time, Valley Current Mode, and Power Saving Mode
Страниц / Страница44 / 2 — ADP1874/ADP1875. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY …
ВерсияA
Формат / Размер файлаPDF / 1.8 Мб
ADP1874/ADP1875. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/12—Rev. 0 to Rev. A. 3/11—Revision 0: Initial Version
ADP1874/ADP1875 Data Sheet TABLE OF CONTENTS REVISION HISTORY 7/12—Rev 0 to Rev A 3/11—Revision 0: Initial Version
Чип стабилизации напряжения, ANALOG DEVICES ADP1875ARQZ-0.3-R7 DC-DC Controller, Current Mode, 2.95V to 20V, 1 Output, Synchronous Buck, 300kHz, QSOP-16
ADP1875ARQZ-0.3-R7
от 143 ₽
ЧипСити
ADP1875ARQZ-0.3-R7
152 ₽
ADP1875ARQZ-0.3-R7
ADP1875ARQZ-0.3-R7
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 6 link to page 6 link to page 6 link to page 6 link to page 7 link to page 8 link to page 18 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 20 link to page 20 link to page 20 link to page 20 link to page 22 link to page 22 link to page 22 link to page 23 link to page 24 link to page 24 link to page 25 link to page 27 link to page 27 link to page 27 link to page 27 link to page 27 link to page 28 link to page 29 link to page 30 link to page 31 link to page 32 link to page 34 link to page 36 link to page 38 link to page 38 link to page 39 link to page 40 link to page 40 link to page 40 link to page 41 link to page 42 link to page 42
Features .. 1 Timer Operation .. 23 Applications ... 1 Pseudo-Fixed Frequency ... 24 General Description ... 1 Power Good Monitoring ... 24 Typical Applications Circuit .. 1 Voltage Tracking ... 25 Revision History ... 2 Applications Information .. 27 Specifications ... 3 Feedback Resistor Divider .. 27 Absolute Maximum Ratings .. 6 Inductor Selection .. 27 Thermal Resistance .. 6 Output Ripple Voltage (ΔVRR) .. 27 Boundary Condition .. 6 Output Capacitor Selection... 27 ESD Caution .. 6 Compensation Network .. 28 Pin Configuration and Function Descriptions ... 7 Efficiency Consideration ... 29 Typical Performance Characteristics ... 8 Input Capacitor Selection .. 30 ADP1874/ADP1875 Block Digram ... 18 Thermal Considerations .. 31 Theory of Operation .. 19 Design Example .. 32 Startup .. 19 External Component Recommendations .. 34 Soft Start .. 19 Layout Considerations ... 36 Precision Enable Circuitry .. 19 IC Section (Left Side of Evaluation Board) ... 38 Undervoltage Lockout ... 19 Power Section ... 38 On-Board Low Dropout Regulator .. 20 Differential Sensing .. 39 Thermal Shutdown ... 20 Typical Application Circuits ... 40 Programming Resistor (RES) Detect Circuit .. 20 12 A, 300 kHz High Current Application Circuit .. 40 Valley Current-Limit Setting .. 20 5.5 V Input, 600 kHz Application Circuit ... 40 Hiccup Mode During Short Circuit ... 22 300 kHz High Current Application Circuit .. 41 Synchronous Rectifier .. 22 Outline Dimensions ... 42 ADP1875 Power Saving Mode (PSM) .. 22 Ordering Guide .. 42
Changes to Table 7 .. 21
Rev. A | Page 2 of 44 Document Outline Features Applications General Description Typical Applications Circuit Table of Contents Revision History Specifications Absolute Maximum Ratings Thermal Resistance Boundary Condition ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics ADP1874/ADP1875 Block Digram Theory of Operation Startup Soft Start Precision Enable Circuitry Undervoltage Lockout On-Board Low Dropout Regulator Thermal Shutdown Programming Resistor (RES) Detect Circuit Valley Current-Limit Setting Hiccup Mode During Short Circuit Synchronous Rectifier ADP1875 Power Saving Mode (PSM) Timer Operation Pseudo-Fixed Frequency Power Good Monitoring Voltage Tracking Applications Information Feedback Resistor Divider Inductor Selection Output Ripple Voltage (ΔVRR) Output Capacitor Selection Compensation Network Output Filter Impedance (ZFILT) Error Amplifier Output Impedance (ZCOMP) Error Amplifier Gain (Gm) Current-Sense Loop Gain (GCS) Crossover Frequency Efficiency Consideration Channel Conduction Loss MOSFET Driver Loss Switching Loss Diode Conduction Loss Inductor Loss Input Capacitor Selection Thermal Considerations Design Example Input Capacitor Inductor Current Limit Programming Output Capacitor Feedback Resistor Network Setup Compensation Network Loss Calculations External Component Recommendations Layout Considerations IC Section (Left Side of Evaluation Board) Power Section Differential Sensing Typical Application Circuits 12 A, 300 kHz High Current Application Circuit 5.5 V Input, 600 kHz Application Circuit 300 kHz High Current Application Circuit Outline Dimensions Ordering Guide
