Клеммные колодки Keen Side
Datasheet OP470S (Analog Devices) - 2
ОписаниеVery Low-Noise Quad Operational Amplifier
Страниц / Страница5 / 2 — Supply. Voltage. (VCC). ... ±18V. dc. Differential. Input. Voltage. 2/. …
Формат / Размер файлаPDF / 478 Кб
Supply. Voltage. (VCC). ... ±18V. dc. Differential. Input. Voltage. 2/. ... ±1V. dc. Differential. Input. Current. 2/. .. ±25mA. Input. Voltage. ... Supply. Voltage
Supply Voltage (VCC) .. ±18V dc Differential Input Voltage 2/ .. ±1V dc Differential Input Current 2/ . ±25mA Input Voltage .. Supply Voltage
OP470AY/QMLL 5962L8856503VCA A Y
5962L8856503VCA
5962L8856503VCA
Supply Voltage (VCC) ... ±18V dc Differential Input Voltage 2/ ... ±1V dc Differential Input Current 2/ .. ±25mA Input Voltage ... Supply Voltage Output Short Circuit Duration .. Continuous Storage Temperature Range .. -65C to +150C Ambient Operating Temperature Range ... -55C to +125C Junction Temperature (TJ)... ... +150°C Absolute Maximum Ratings Notes: 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ The inputs are protected by back-to-back diodes. Current limiting resistors are not used in order to achieve low noise performance. If the differential input voltage exceeds ±1V, the input current should be limited to ±25mA. In accordance with class-K version of MIL-PRF-38534, Appendix C, Table C-II, except as modified herein. (a) Qual Sample Size and Qual Acceptance Criteria – 10/0 (b) Qual Sample Package – DIP (c) Pre-screen electrical test over temperature performed post-assembly prior to die qualification.  Table I Notes: 1/ VCC = ±15V, RS = 50, and TA = +25C, unless otherwise specified. 2/ IS limit equals the total of all amplifiers.
