Datasheet AD8009 (Analog Devices) - 3
Описание1 GHz, 5,500 V/µs Low Distortion Amplifier
Страниц / Страница16 / 3 — AD8009. SPECIFICATIONS (@ TA = 25. C, VS =. 5 V, RL = 100. , for R …
ВерсияF
Формат / Размер файлаPDF / 296 Кб
AD8009. SPECIFICATIONS (@ TA = 25. C, VS =. 5 V, RL = 100. , for R Package: RF = 301. for G = +1, +2,. RF = 200. for G = +10)
AD8009 SPECIFICATIONS (@ TA = 25 C, VS = 5 V, RL = 100 , for R Package: RF = 301 for G = +1, +2, RF = 200 for G = +10)
53 предложений от 30 поставщиков
AD8009ARZ-REEL
81 ₽
727GS
AD8009ARZ-REEL
85 ₽
ЧипСити
AD8009ARZ-REEL7
89 ₽
AD8009ARZ-REEL7
от 179 ₽
AD8009 SPECIFICATIONS (@ TA = 25 C, VS = 5 V, RL = 100 , for R Package: RF = 301 for G = +1, +2, RF = 200 for G = +10). AD8009AR/JRT Model Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Small Signal Bandwidth, VO = 0.2 V p-p G = +1, RF = 301 Ω 630 MHz G = +2 430 MHz G = +10 300 MHz Large Signal Bandwidth, VO = 2 V p-p G = +2 365 MHz G = +10 250 MHz Gain Flatness 0.1 dB, VO = 0.2 V p-p G = +2, RL = 150 Ω 65 MHz Slew Rate G = +2, RL = 150 Ω, 4 V Step 2,100 V/µs Settling Time to 0.1% G = +2, RL = 150 Ω, 2 V Step 10 ns G = +10, 2 V Step 25 ns Rise and Fall Time G = +2, RL = 150 Ω, 4 V Step 0.725 ns HARMONIC/NOISE PERFORMANCE Second Harmonic G = +2, VO = 2 V p-p 10 MHz –74 dBc 20 MHz –67 dBc 70 MHz –48 dBc Third Harmonic 10 MHz –76 dBc 20 MHz –72 dBc 70 MHz –44 dBc Input Voltage Noise f = 10 MHz 1.9 nV/√Hz Input Current Noise f = 10 MHz, +In 46 pA/√Hz f = 10 MHz, –In 41 pA/√Hz DC PERFORMANCE Input Offset Voltage 1 4 mV –Input Bias Current 50 150 ±µA +Input Bias Voltage 50 150 ±µA INPUT CHARACTERISTICS Input Resistance +Input 110 kΩ –Input 8 Ω Input Capacitance +Input 2.6 pF Input Common-Mode Voltage Range 1.2 to 3.8 V Common-Mode Rejection Ratio VCM = 1.5 V to 3.5 V 50 52 dB OUTPUT CHARACTERISTICS Output Voltage Swing 1.1 to 3.9 V Output Current RL = 10 Ω, PD Package = 0.7 W 175 mA Short-Circuit Current 330 mA POWER SUPPLY Operating Range +5 ±6 V Quiescent Current 10 12 mA Power Supply Rejection Ratio VS = 4.5 V to 5.5 V 64 70 dB Specifications subject to change without notice. REV. F –3– Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS PRODUCT DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics APPLICATIONS RF Filter Driver RGB Monitor Driver Driving a Capacitive Load OUTLINE DIMENSIONS Revision History
