Datasheet ADCMP580, ADCMP581, ADCMP582 (Analog Devices) - 6
ОписаниеUltrafast SiGe Voltage Comparators
Страниц / Страница16 / 6 — ADCMP580/ADCMP581/ADCMP582. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL …
ВерсияB
Формат / Размер файлаPDF / 412 Кб
ADCMP580/ADCMP581/ADCMP582. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL CONSIDERATIONS. Table 3. Parameter. Rating. ESD CAUTION
ADCMP580/ADCMP581/ADCMP582 Data Sheet ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS Table 3 Parameter Rating ESD CAUTION
37 предложений от 16 поставщиков
Интегральные микросхемы Линейные микросхемы - Компараторы
ЧипСити
ADCMP580BCPZ-RL7
1 097 ₽
ADCMP580BCPZ-RL7
от 1 098 ₽
T-electron
ADCMP580BCPZ-RL7
1 215 ₽
ADCMP580BCPZ-RL7
от 3 194 ₽
ADCMP580/ADCMP581/ADCMP582 Data Sheet ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS Table 3. Parameter Rating
The ADCMP580/ADCMP581/ADCMP582 16-lead LFCSP SUPPLY VOLTAGES option has a junction-to-ambient thermal resistance (θJA) of Positive Supply Voltage (V 70°C/W in stil air. CCI to GND) −0.5 V to +6.0 V Negative Supply Voltage (VEE to GND) –6.0 V to +0.5 V Logic Supply Voltage (VCCO to GND) −0.5 V to +6.0 V
ESD CAUTION
INPUT VOLTAGES Input Voltage −3.0 V to +4.0 V Differential Input Voltage −2 V to +2 V Input Voltage, Latch Enable −2.5 V to +5.5 V HYSTERESIS CONTROL PIN Applied Voltage (HYS to V EE) −5.5 V to +0.5 V Maximum Input/Output Current 1 mA OUTPUT CURRENT ADCMP580 (CML) −25 mA ADCMP581 (NECL) −40 mA ADCMP582 (PECL) −40 mA TEMPERATURE Operating Temperature Range, Ambient −40°C to +125°C Operating Temperature, Junction 125°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 6 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING INFORMATION ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TYPICAL APPLICATION CIRCUITS APPLICATIONS INFORMATION POWER/GROUND LAYOUT AND BYPASSING ADCMP580/ADCMP581/ADCMP582 FAMILY OF OUTPUT STAGES USING/DISABLING THE LATCH FEATURE OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT OUTLINE DIMENSIONS ORDERING GUIDE NOTES
