Datasheet ADRV9009 (Analog Devices) - 3
ОписаниеIntegrated Dual RF Tx, Rx, and Observation Rx
Страниц / Страница127 / 3 — Data Sheet. ADRV9009. 6/2018—Revision A: Initial Version
ВерсияB
Формат / Размер файлаPDF / 3.6 Мб
Data Sheet ADRV9009 6/2018—Revision A: Initial Version
5 предложений от 5 поставщиков
, RF Transceiver 1.3V/1.8V/1.89V T/R
IC Home
ADRV9009BBCZ-REEL
45 052 ₽
ADRV9009BBCZ-REEL
50 743 ₽
ADRV9009BBCZ-REEL
ADRV9009BBCZ-REEL
Data Sheet ADRV9009
Changes to Signals with Lowest Routing Priority Section and Deleted RF Port Interface Overview Section .. 117 Figure 439 ...109 Changes to Figure 448 Caption ... 117 Changes to RF Routing Guidelines Section and Moved Table 11 .. 120 Figure 440 Caption ..110 Changes to Figure 456 Caption to Figure 459 Caption .. 121 Change to Figure 441 Caption ...111 Changes to General Receiver Path Interface Section ... 122 Changes to Transmitter Balun DC Feed Changes to Figure 463 .. 124 Supplies Section ...112 Changes to Figure 464 and Figure 465 ... 125 Changes to Stripline Transmission Lines vs. Microstrip Deleted Endnote 1, Table 12 to Endnote 1, Table 15; Transmission Lines Section ...113 Renumbered Sequentially, and Endnote 2, Table 16 and Moved Figure 444 to Isolation Techniques Used on the Endnote 2, Table 17 ... 126 ADRV9009-W/PCBZ Section ...114 Changes to Table 15 .. 126 Moved Figure 446 ..115 Changes to Isolation Between JESD204B Lines Section ..115
Changes to RF Port Interface Information Section ..116 Rev. B | Page 3 of 127 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Current and Power Consumption Specifications Timing Diagrams Absolute Maximum Ratings Reflow Profile Thermal Management Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 75 MHz to 525 MHz Band 650 MHz to 3000 MHz Band 3400 MHz to 4800 MHz Band 5100 MHz to 5900 MHz Band Transmitter Output Impedance Observation Receiver Input Impedance Receiver Input Impedance Terminology Theory of Operation Transmitter Receiver Observation Receiver Clock Input Synthesizers RF PLL Clock PLL SPI JTAG Boundary Scan Power Supply Sequence GPIO_x Pins Auxiliary Converters AUXADC_x Auxiliary DAC x JESD204B Data Interface Applications Information PCB Layout and Power Supply Recommendations Overview PCB Material and Stackup Selection Fanout and Trace Space Guidelines Component Placement and Routing Guidelines Signals with Highest Routing Priority Signals with Second Routing Priority Signals with Lowest Routing Priority RF and JESD204B Transmission Line Layout RF Routing Guidelines Transmitter Balun DC Feed Supplies JESD204B Trace Routing Recommendations Routing Recommendations Stripline Transmission Lines vs. Microstrip Transmission Lines Isolation Techniques Used on the ADRV9009-W/PCBZ Isolation Goals Isolation Between JESD204B Lines RF Port Interface Information RF Port Impedance Data Advanced Design System (ADS) Setup Using the DataAccessComponent and SEDZ File Transmitter Bias and Port Interface General Receiver Path Interface Impedance Matching Network Examples Outline Dimensions Ordering Guide
