Datasheet ADuM6210, ADuM6211, ADuM6212 (Analog Devices) - 7
ОписаниеDual-Channel Isolators with Integrated DC-to-DC Converters
Страниц / Страница23 / 7 — Data Sheet. ADuM6210/ADuM6211/ADuM6212. ELECTRICAL CHARACTERISTICS—5 V …
ВерсияD
Формат / Размер файлаPDF / 530 Кб
Data Sheet. ADuM6210/ADuM6211/ADuM6212. ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY
Data Sheet ADuM6210/ADuM6211/ADuM6212 ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY
12 предложений от 11 поставщиков
Digital Isolator 4CH 25Mbps 20Pin SSOP T/R
ADUM6212BRSZ-RL7
516 ₽
ЧипСити
ADUM6212BRSZ-RL7
576 ₽
TradeElectronics
ADUM6212BRSZ-RL7
ADUM6212BRSZ-RL7
All typical specifications are at TA = 25°C, VDD1 = VDDP = 5 V, VDD2 = 3.3 V, VSEL resistor network: R1 = 10 kΩ, R2 = 16.9 kΩ between VISO and GNDISO. Minimum/maximum specifications apply over the entire recommended operation range, which is 4.5 V ≤ VDD1, VDDP ≤ 5.5 V, 3.135 V ≤ VDD2 ≤ 3.6 V, and −40°C ≤ TA ≤ +105°C, unless otherwise noted. Switching specifications are tested with CL = 15 pF and CMOS signal levels, unless otherwise noted.
Table 11. DC-to-DC Converter Static Specifications Parameter Symbol Min Typ Max Unit Test Conditions/Comments
DC-TO-DC CONVERTER SUPPLY Setpoint VISO 3.135 3.3 3.51 V IISO = 15 mA, R1 = 10 kΩ, R2 = 16.9 kΩ Thermal Coefficient VISO (TC) −26 μV/°C Line Regulation VISO (LINE) 20 mV/V IISO = 15 mA, VDDP = 4.5 V to 5.5 V Load Regulation VISO (LOAD) 1.3 3 % IISO = 3 mA to 27 mA Output Ripple VISO (RIP) 50 mV p-p 20 MHz bandwidth, CBO = 0.1 μF||10 μF, IISO = 27 mA Output Noise VISO (NOISE) 130 mV p-p CBO = 0.1 μF||10 μF, IISO = 27 mA Switching Frequency fOSC 125 MHz Pulse-Width Modulation fPWM 600 kHz Frequency Output Supply IISO (MAX) 30 mA VISO > 3.135 V Efficiency at IISO (MAX) 20 24 35 % IISO = 27 mA IDDP, No VISO Load IDDP (Q) 3.2 8 mA IDDP, Full VISO Load IDDP (MAX) 70 85 105 mA Thermal Shutdown Shutdown Temperature 154 °C Thermal Hysteresis 10 °C
Table 12. Data Channel Supply Current 1 Mbps—A, B, C Grades 25 Mbps—B, C Grades 100 Mbps—C Grade Test Conditions/ Parameter Symbol Min Typ Max Min Typ Max Min Typ Ma Unit x Comments
SUPPLY CURRENT ADuM6210 IDD1 1.1 1.6 6.2 7.0 20 25 mA CL = 0 pF IDD2 2.0 3.5 2.7 4.6 4.8 9.0 mA CL = 0 pF ADuM6211 IDD1 2.1 2.7 4.9 6.5 15 19 mA CL = 0 pF IDD2 1.7 2.3 3.9 6.2 11 15 mA CL = 0 pF ADuM6212 IDD1 2.0 3.5 2.7 4.6 4.8 9.0 mA CL = 0 pF IDD2 1.1 1.6 6.2 7.0 20 25 mA CL = 0 pF
Table 13. Switching Specifications A Grade B Grade C Grade Test Conditions/ Parameter Symbol Min Typ Max Min Typ Max Min Typ Max Unit Comments
SWITCHING SPECIFICATIONS Data Rate 1 25 100 Mbps Within PWD limit Propagation Delay tPHL, tPLH 50 35 20 25 31 ns 50% input to 50% output Pulse Width Distortion PWD 10 3 2.5 ns |tPLH − tPHL| Pulse Width PW 1000 40 10 ns Within PWD limit Propagation Delay Skew tPSK 38 16 12 ns Between any two units Channel Matching Codirectional tPSKCD 5 3 2 ns Opposing Direction tPSKOD 10 6 5 ns Jitter 2 2 1 ns Rev. D | Page 7 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/5 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—3.3 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY ELECTRICAL CHARACTERISTICS—5 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY PACKAGE CHARACTERISTICS REGULATORY APPROVALS INSULATION AND SAFETY-RELATED SPECIFICATIONS DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TRUTH TABLES TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PCB LAYOUT THERMAL ANALYSIS PROPAGATION DELAY PARAMETERS EMI CONSIDERATIONS DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION INSULATION LIFETIME OUTLINE DIMENSIONS ORDERING GUIDE
