Datasheet MAX9021, MAX9022, MAX9024 (Maxim) - 6
ПроизводительMaxim
ОписаниеMicropower, Ultra-Small, Single/Dual/Quad Single-Supply Comparators
Страниц / Страница8 / 6 — Micropower, Ultra-Small, Single/Dual/Quad, Single-Supply Comparators. …
Формат / Размер файлаPDF / 705 Кб
Micropower, Ultra-Small, Single/Dual/Quad, Single-Supply Comparators. Board Layout and Bypassing. Biasing for Data Recovery
Micropower, Ultra-Small, Single/Dual/Quad, Single-Supply Comparators Board Layout and Bypassing Biasing for Data Recovery
50 предложений от 19 поставщиков
Аналоговый компаратор, с полным размахом напряжения, Micropower, 2 Компаратора, 3 мкс, 2.5В до 5.5В
727GS
MAX9022AUA+
Maxim
от 12 ₽
MAX9022AUA+T
Maxim
39 ₽
MAX9022AUA+
Maxim
от 67 ₽
MAX9022AUA+
Maxim
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
VDD R1 VDD VDD VDD R2 IN+ IN+ VIN VREF OUT OUT 10kΩ IN- IN- VIN MAX9021 MAX9021 0.1µF VSS VSS Figure 1. Additional Hysteresis Figure 2. Time Averaging of the Input Signal for Data Recovery 2) The hysteresis band will be:
V Use 100nF bypass as a starting point. Minimize signal HYS = VTH - VTL = VDD(R2 / (R1 + R2)) trace lengths to reduce stray capacitance. Minimize the 3) In this example, let VDD = 5V and VREF = 2.5V. capacitive coupling between IN- and OUT. For slow- moving input signals (rise time > 1ms), use a 1nF VTH = 2.5V + 2.5V(R2 / (R1 + R2)) capacitor between IN+ and IN-. and
VTL = 2.5V[(1 - (R2 / (R1 + R2))] Digital data is often embedded into a bandwidth and amplitude-limited analog path. Recovering the data can 4) Select R2. In this example, we will choose 1kΩ. be difficult. Figure 2 compares the input signal to a
MAX9021/MAX9022/MAX9024
5) Select VHYS. In this example, we will choose 50mV. time-averaged version of itself. This self-biases the 6) Solve for R1. threshold to the average input voltage for optimal noise margin. Even severe phase distortion is eliminated from VHYS = VDD(R2 / (R1 + R2)) the digital output signal. Be sure to choose R1 and C1 0.050V = 5(1000Ω/(R1 + 1000Ω)) V so that: where R1 ≈ 100kΩ, VTH = 2.525V, and VTL = 2.475V. fCAR >> 1 / (2πR1C1) The above-described design procedure assumes rail- where fCAR is the fundamental carrier frequency of the to-rail output swing. If the output is significantly loaded, digital data stream. the results should be corrected.
6 _______________________________________________________________________________________
