Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet IX4351NE (IXYS) - 5
ПроизводительIXYS
Описание9A Low Side SiC MOSFET & IGBT Driver
Страниц / Страница12 / 5 — IX4351NE. Parameter. Conditions. Symbol. Minimum. Typical. Maximum. …
Формат / Размер файлаPDF / 334 Кб
IX4351NE. Parameter. Conditions. Symbol. Minimum. Typical. Maximum. Units. www.ixysic.com
IX4351NE Parameter Conditions Symbol Minimum Typical Maximum Units www.ixysic.com
I
IX4351NE
NTEGRATED CIRCUITS DIVISION 1.5.3 Charge Pump Section
Negative Bias Rail Voltage Range - VSS -8 - -3.5 V Maximum VSS Current CFLY=66nF, RFLY=33 ISS - - 50 mA Charge Pump Frequency - fOSC 90 124 160 kHz 1.5.4 Desaturation Section
DESAT Source Current VDESAT=0V IDESAT 400 570 750 A DESAT Threshold Voltage - VTH,DESAT 6 6.8 8 V Blanking Time - tBLANK - 250 - ns DESAT Pull Down Resistance - RDESAT* - 900 - * External component 1.5.5 Thermal Shutdown Section
Thermal Shutdown Temperature - TSD - 160 - °C Thermal Shutdown Hysteresis - TSDHYS - 20 - °C 1.5.6 Logic Input Section
High Level Input Voltage - VINH 2.2 - - V Low Level Input Voltage - VINL - - 1 V Input Hysteresis - VINHYS 0.2 0.4 - V High Level Input Current VIN=5V IINH - - 70 A Low Level Input Current VIN=0V IINL - - -10 A Input Pull-Down Resistance - RIN - 100 - k 1.5.7 FAULT Section
Output Low Voltage IFAULT=20mA VFAULTL - - 0.8 V Output Leakage Current VFAULT=20V IFAULT - 0.1 10 A DESAT Detect to FAULT Delay - tFAULTDLY - 150 - ns R02
www.ixysic.com
5 Document Outline Features Applications Description Ordering Information 1 Specifications 1.1 Package Pinout 1.2 Pin Description 1.3 Absolute Maximum Ratings 1.4 Recommended Operating Conditions 1.5 Electrical Characteristics 1.6 Thermal Characteristics 2 Performance Data 3 Performance Data (Cont.) 4 Functional Description 4.1 Logic Input (IN) 4.2 Gate Drive Outputs (OUTSRC and OUTSNK) 4.3 Internal 4.6V Regulator (VREG) 4.4 Negative VSS Charge Pump Regulator 4.5 Desaturation Detection and Protection 4.6 Thermal Shutdown 4.7 FAULT Output 5 Manufacturing Information 5.1 Moisture Sensitivity 5.2 ESD Sensitivity 5.3 Soldering Profile 5.4 Board Wash 5.5 Mechanical Dimensions
