Datasheet AL8843Q (Diodes) - 5
ПроизводительDiodes
ОписаниеAutomotive Compliant 40V 3A Step-Down LED Driver
Страниц / Страница18 / 5 — AL8843Q. Electrical Characteristics. Symbol. Parameter. Condition. Min. …
AL8843Q. Electrical Characteristics. Symbol. Parameter. Condition. Min. Typ. Max. Unit. SUPPLY VOLTAGE. HYSTERESTIC CONTROL
AL8843Q Electrical Characteristics Symbol Parameter Condition Min Typ Max Unit SUPPLY VOLTAGE HYSTERESTIC CONTROL
35 предложений от 11 поставщиков
IC: driver; преобразователь DC/DC,контроллер LED; 3А; SO8-EP
AL8843QSP-13
Diodes
от 9.68 ₽
AL8843QSP-13
Diodes
28 ₽
Эиком
AL8843QSP-13
Diodes
от 70 ₽
AL8843QSP-13
Diodes
от 70 ₽
(@VIN = 16V, TA = -40°C to +125°C. Typical values are at TA = +25°C, unless otherwise specified.)
VIN Input Voltage — 4.5 — 40 V IQ Quiescent Current CTRL Pin Floating, VIN = 16V — 0.35 — mA VUVLO Under Voltage Lockout VIN Rising — 3.9 — V VUVLO_HYS Under Voltage Lockout Hysteresis — — 250 — mV
HYSTERESTIC CONTROL
Measured on SET Pin with VSET Mean Current Sense Threshold Voltage 96 100 104 mV Respect to VIN VSET_HYS Sense Threshold Hysteresis — — ±13 — % ISET SET Pin Input Current VSET = VIN -0.1V — 8 — µA
ENABLE AND DIMMING
VCTRL Voltage Range from 10% to 100% DC Dimming Relative to GND For Analog Dimming 0.4 — 2.5 V — Analog Dimming Range — 10 — 100 % VCTRL_ON DC Voltage on CTRL Pin for Analog Dimming On VCTRL Rising — 0.45 — V VCTRL_OFF DC Voltage on CTRL Pin for Analog Dimming Off VCTRL Falling — 0.40 — V
SWITCHING OPERATION
RON SW Switch On Resistance @ISW = 100mA — 0.2 — Ω ISW_LEAK SW Switch Leakage Current — — — 8 μA tSS Soft Start Time VIN = 16V, CCTRL = 1nF — 1.5 — ms fSW Switching Frequency VIN = 16V, VO = 9.6V (3 LEDs) — 250 — kHz L= 47μH, ILED =1A fSW_MAX Recommended Maximum Switch Frequency — — — 1 MHz tON_REC Recommended Minimum Switch ON Time For 4% Accuracy — 500 — ns tPD Internal Comparator Propagation Delay (Note 8) — — 100 — ns
THERMAL SHUTDOWN
TOTP Over Temperature Protection — — +150 — °C TOTP_HYS Temperature Protection Hysteresis — — +30 — °C Note: 8. Guaranteed by design. AL8843Q 5 of 18 October 2019 Document number: DS41943 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Applications Features
