Datasheet AOZ6682CI (Alpha & Omega) - 2
ПроизводительAlpha & Omega
ОписаниеEZBuck 2A Synchronous Buck Regulator
Страниц / Страница14 / 2 — AOZ6682CI. Ordering Information. Part Number. Ambient Temperature Range. …
Формат / Размер файлаPDF / 808 Кб
AOZ6682CI. Ordering Information. Part Number. Ambient Temperature Range. Package. Environmental. Pin Configuration. TSOT23. (Top View)
AOZ6682CI Ordering Information Part Number Ambient Temperature Range Package Environmental Pin Configuration TSOT23 (Top View)
26 предложений от 7 поставщиков
Управление питанием (PMIC)
AOZ6682CI
17 ₽
Элитан
AOZ6682CI
Alpha & Omega
22 ₽
AOZ6682CI
от 22 ₽
T-electron
AOZ6682CI
1 717 ₽
Открытие интернет-магазина MEAN WELL Market
AOZ6682CI -40°C to +125°C TSOT23-6L RoHS AOS Green Products use reduced levels of Halogens, and are also RoHS compliant. Please visit www.aosmd.com/media/AOSGreenPolicy.pdf for additional information.
Pin Configuration
GND 1 6 BST LX 2 5 EN VIN 3 4 FB
TSOT23 (Top View) Pin Description Pin Number Pin Name Pin Function
1 GND System ground. 2 LX Switching node connects to main inductor terminal. Supply voltage input. When VIN rises above the UVLO threshold and EN is logic high, the 3 VIN device will start up. Feedback input. The FB pin is used to set the output voltage through a resistor voltage 4 FB divider between the Output and GND. Enable input. Pull EN to logic high will enable the device. Pull EN to logic low will disable 5 EN the device. EN pin must be connected to VIN if no Enable control is required. 6 BST Bootstrap input. Connect a capacitor to LX (Pin 2). Typical value is 0.1uF. Rev. 1.0 December 2018
www.aosmd.com
Page 2 of 14
