Datasheet TMC2590 (TRINAMIC) - 10
ПроизводительTRINAMIC
ОписаниеPower Driver for Stepper Motors
Страниц / Страница64 / 10 — 4 Standalone Operation. CSN: SELECTION OF MOTOR CURRENT (USE FOR …
Формат / Размер файлаPDF / 2.0 Мб
4 Standalone Operation. CSN: SELECTION OF MOTOR CURRENT (USE FOR STANDSTILL CURRENT REDUCTION) CSN (CFG1). Chopper Setting
4 Standalone Operation CSN: SELECTION OF MOTOR CURRENT (USE FOR STANDSTILL CURRENT REDUCTION) CSN (CFG1) Chopper Setting
21 предложений от 10 поставщиков
Motor / Motion / Ignition Controllers & Drivers Stepper Motor Driver, SPI, Step/Dir, 5-60V, TQFP32
TMC2590-TA-T
Maxim
171 ₽
TMC2590-TA-T
213 ₽
Элитан
TMC2590-TA
439 ₽
TMC2590-TA
TRINAMIC
от 789 ₽
Открытие интернет-магазина MEAN WELL Market
TMC2590 DATASHEET (V1.0 / 2019-FEB-22) 10
Standalone operation is the easiest way to use the IC. In this mode, three pins configure for the most common settings. Just use the standard application circuit, tie low / high the SPI input pins to set the desired basic operation parameters and choose a sense resistor to fit the required motor current. However, advanced configuration and access to individual diagnostics only is possible via SPI.
GND Current Scale CS=15. Use for standstill current reduction, or to adapt lower sense resistor value. VCC_IO Current Scale CS=31. Maximum current. Control motor current by adapting sense resistors.
SCK: SELECTION OF CHOPPER HYSTERESIS (ADAPT FOR LOWEST MOTOR NOISE & VIBRATION) SCK (CFG2) Chopper Setting
GND Low hysteresis (HSTRT=2, HEND=4), use for larger motor. VCC_IO Medium hysteresis (HSTRT=6, HEND=4), typical for Nema17 or smaller motor, or for high speed motors with high coil currents.
SDI: SELECTION OF MICROSTEP RESOLUTION (ADAPT TO STEP PULSE GENERATOR) SDI (CFG3) Chopper Setting
GND 256 Microsteps full resolution for Step/Dir interface VCC_IO 16 Microsteps with internal interpolation to 256 microsteps
+VM +VCCIO TMC2590 VCC_IO Gate driver HS Gate Driver r STEP eil N pitl S u Sine Table x Chopper DIR M p 4*256 entry BM etS Gate driver Gate Driver 2 Phase Stepper ST_ALONE Stand Alone CSN/CFG1 Current LS SCK/CFG2 coolStep Hysteresis SPI control, SDI/CFG3 Config & Diags RS Microsteps SDO 2 x Current RS RS Protection 2 x DAC Enable/ ENN stallGuard2 Comparator & Diagnostics Disable SG_TST Figure 3 Standalone configuration
Standalone mode automatically enables resonance dampening (EN_PFD) and 136°C overtemperature detection (OT_SENSE), sensitive high-side short detection (SHRTSENSE) and enable low side short protection (S2VS). Driver strength becomes set to SLPL=SLPH=3. TOFF is 4, TBL is 36 clocks in this mode. All other bits are cleared to 0. In standalone configuration, StallGuard level is fixed to SGT=2. This setting will work for homing with many 42mm and larger motors in a suitable velocity range. Adapt to full or half current as fitting using CSN configuration pin. Resulting configuration words: SDI=0: $00200 / SDI=1: $00204 SCK=0: $90224 / SCK=1: $90264 CSN=0: $C020F / CSN=1: $C021F $E810F, $A0000 www.trinamic.com
