Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet RV1S9160A (Renesas) - 3
ПроизводительRenesas
ОписаниеHIGH CMR, 15Mbps CMOS OUTPUT, LOW FORWARD-CURRENT(IF) 3.3V/5V OPERATION, 5-PIN SOP PHOTOCOUPLER
Страниц / Страница14 / 3 — RV1S9160A. 章題. MARKING. EXAMPLE. Type. Number. *). 9160. Assembly. Lot. …
Формат / Размер файлаPDF / 6.3 Мб
RV1S9160A. 章題. MARKING. EXAMPLE. Type. Number. *). 9160. Assembly. Lot. N131. Bar. :. Pb-Free. R. No. 1. pin. Mark. Initial. of. Renesas. (Engraved. R). N. 1. 31. Week
RV1S9160A 章題 MARKING EXAMPLE Type Number *) 9160 Assembly Lot N131 Bar : Pb-Free R No 1 pin Mark Initial of Renesas (Engraved R) N 1 31 Week
T-electron
RV1S9160ACCSP100V#SC07 345 ₽
RV1S9160A 章題 MARKING EXAMPLE Type Number *) 9160 Assembly Lot N131 Bar : Pb-Free R No. 1 pin Mark Initial of Renesas (Engraved R) N 1 31 Week Assembled Year Assembled (Last 1 Digit) Rank Code *Applicable type numbers are listed below. *) RV1S 9160 ACCSP-100x Marking type number. “RV1S” and “ACCSP-100x” are omitted from original type numbe r. ORDERING INFORMATION Part Number Order Number Solder Plating Packing Style Safety Standard Application Specification Approval Part Number*1 RV1S9160ACCSP- RV1S9160ACCSP Pb-Free Embossed Tape 2 500 Standard products RV1S9160A 100C -100C#KC0 (Ni/Pd/Au) pcs/reel (UL, CSA approved) RV1S9160ACCSP- RV1S9160ACCSP Embossed Tape 2 500 UL, CSA, 100V -100V#KC0 pcs/reel DIN EN 60747-5-5 approved Notes: *1. For the application of the Safety Standard, fol owing part number should be used. ABSOLUTELY MAXIMUM RATINGS (TA=25°C, unless otherwise specified) Parameter Symbol Ratings Unit Diode Forward Current *1 IF 20 mA Reverse Voltage VR 5 V Detector Supply Voltage VDD 6 V Output Voltage VO 6 V Output Current IO 10 mA Power Dissipation *2 Pc 200 mW Isolation Voltage *3 BV 3 750 Vr.m.s. Operating Ambient Temperature TA -40 to +125 C Storage Temperature Tstg -55 to +150 C Notes: 1. Reduced to 0.93mA/°C at TA=110°C or more 2. Reduced to 4.57mW/°C at TA=90°C or more 3. AC Voltage for 1minite at TA=25°C, RH=60% between input and output. Pins 1-2 shorted together, 3-5 shorted together. R08DS0167EJ0100 Rev.1.00 Page 3 of 13 Jun 4, 2019
