Datasheet ADL5201 (Analog Devices) - 9
ОписаниеWide Dynamic Range, High Speed, Digitally Controlled VGA
Страниц / Страница26 / 9 — Data Sheet. ADL5201. –50. –20. –60. –40. –11.5dB. 0dB. –30. +10dB. –70. …
ВерсияC
Формат / Размер файлаPDF / 909 Кб
Data Sheet. ADL5201. –50. –20. –60. –40. –11.5dB. 0dB. –30. +10dB. –70. +20dB. Bc –70. Bc). –80. HD2. HD3. HD2 (. HD3 (. N –90. –90. O –100. –110. DI –110. IC DI. –120
Data Sheet ADL5201 –50 –20 –60 –40 –11.5dB 0dB –30 +10dB –70 +20dB Bc –70 Bc) –80 HD2 HD3 HD2 ( HD3 ( N –90 –90 O –100 –110 DI –110 IC DI –120
13 предложений от 12 поставщиков
Усилитель IC и модуль RF, Programmable/Variable Amplifier, 1Channels, 1 Amplifier, 700MHz, -40℃, 85℃, 4.5V to 5.5V
727GS
ADL5201ACPZ-R7
от 2 500 ₽
ИМЭК
Россия и страны ТС
ADL5201ACPZ-R7
4 216 ₽
TradeElectronics
ADL5201ACPZ-R7
ADL5201ACPZ-R7
Data Sheet ADL5201 –50 –20 –60 –40 –11.5dB –11.5dB 0dB 0dB –60 –30 +10dB +10dB ) ) –70 –50 +20dB +20dB c) Bc –70 –40 Bc Bc) B d d d d ( ( –80 –60 –80 –50 HD2 HD3 HD2 ( HD3 ( N N N –90 –70 N –90 –60 IO IO IO IO T T RT RT R R O –100 –70 O O –100 –80 O T T T T S S S S –110 –80 DI –110 –90 DI IC DI IC DI IC IC N N N –120 –90 N O O O O M M –120 –100 –130 –100 HAR HAR HARM HARM –130 –110 –140 –110 –150 –120 –140 –120
7
0 50 100 150 200 250 300 350 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 6
01 020 88-
FREQUENCY (MHz) P
093
OUT (dBm)
09388- Figure 18. Harmonic Distortion vs. Frequency at Four Gain Codes Figure 21. Harmonic Distortion vs. Power at Four Gain Codes, Frequency = 140 MHz
–60 –40 –80 –60 TA = –40°C TA = –40°C T T –70 A = +25°C –50 A = +25°C ) T ) A = +85°C ) TA = +85°C ) –90 –70 Bc Bc Bc Bc d d d d –80 –60 ( ( 2 ( 3 ( HD HD HD2 –100 –80 HD3 N –90 –70 N N N IO IO IO IO T T T T R R R –100 R O –80 O –110 –90 T T TO TO IS IS S S D –110 DI DI –90 D IC IC C C N N –120 –100 NI NI O O O O –120 –100 M M RM RM HA HA HAR –130 –110 HAR –130 –110 –140 –120 –140 –120
8
-01 021 8-
FREQUENCY (MHz)
388
P
09
OUT (dBm)
0938 Figure 19. Harmonic Distortion vs. Frequency, Three Temperatures Figure 22. Harmonic Distortion vs. Power, Frequency = 140 MHz, Three Temperatures
25 20 18 20 16 14 ) TA = –40°C m 15 ) B m 12 TA = +25°C d B ( d TA = +85°C B ( B 10 1d 10 1d OP 8 OP 6 INPUT 5 MAX RATINGS 4 BOUNDARY 2 0
9
0 –15 –10 –5 0 5 10 15 20 25
01
0 50 100 150 200 250 300 350 400
022
PROGRAMMED GAIN (dB)
388- 09
FREQUENCY (MHz)
09388- Figure 20. OP1dB vs. Programmed Gain at 140 MHz, Low Power Mode Figure 23. OP1dB vs. Frequency at Maximum Gain, Three Temperatures, Low Power Mode Rev. C | Page 9 of 26 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CHARACTERIZATION AND TEST CIRCUITS THEORY OF OPERATION DIGITAL INTERFACE OVERVIEW PARALLEL DIGITAL INTERFACE SERIAL PERIPHERAL INTERFACE (SPI) Fast Attack UP/DOWN INTERFACE Truth Table LOGIC TIMING CIRCUIT DESCRIPTION BASIC STRUCTURE INPUT SYSTEM OUTPUT AMPLIFIER GAIN CONTROL APPLICATIONS INFORMATION BASIC CONNECTIONS ADC DRIVING LAYOUT CONSIDERATIONS EVALUATION BOARD EVALUATION BOARD CONTROL SOFTWARE SCHEMATICS AND ARTWORK EVALUATION BOARD CONFIGURATION OPTIONS Configuration Options for the Main Section Configuration Options for the USB Section OUTLINE DIMENSIONS ORDERING GUIDE
