Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet HMC996LP4E (Analog Devices) - 6
ОписаниеAnalog Variable Gain Amplifier SMT, 5 - 12 GHz
Страниц / Страница8 / 6 — HMC996LP4E. VARIABLE GAIN AMPLIFIER. 5 - 12 GHz. Pin Descriptions
Формат / Размер файлаPDF / 491 Кб
HMC996LP4E VARIABLE GAIN AMPLIFIER 5 - 12 GHz Pin Descriptions
28 предложений от 15 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
LIXINC Electronics
HMC996LP4E
от 133 ₽
ЧипСити
HMC996LP4E
1 582 ₽
Элитан
HMC996LP4E
4 839 ₽
Allelco
HMC996LP4E
HMC996LP4E
v01.0112
pin number function Description interface Schematic 1, 2, 6, 8, 10, The pins are not connected internally: however all data T 11, 13, 17, 18, n/C shown herein was measured with these pins connected 20, 21, 22, 23 to rf/DC ground externally m These pins and exposed ground paddle must be connected to 3, 5, 14, 16 GnD rf/DC ground. r - S ie lif This pad is aC coupled 4 rfin and matched to 50 Ohm. p m a in Gate control for amplifier. adjust voltage to achieve typical 7, 12 Vgg1, 2 idd. please follow “mmiC amplifier biasing procedure” a application note. le G b Gain control Voltage for the amplifier. See assembly ia 9 Vctrl diagram for required external components. r a V This pad is aC coupled 15 rfOUT and matched to 50 Ohm. Drain bias Voltage for the amplifier. See assembly diagram for 19, 24 Vdd1, 2 required external components Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
