Datasheet L5965 (STMicroelectronics) - 8
ПроизводительSTMicroelectronics
ОписаниеMultiple power management for automotive vision and radar systems
Страниц / Страница85 / 8 — L5965. Electrical characteristics. Table 5. Maximum suggested power. …
L5965. Electrical characteristics. Table 5. Maximum suggested power. Symbol. Tamb 125 ° C. Tamb 105 ° C. Tamb 80 ° C. 3.3
L5965 Electrical characteristics Table 5 Maximum suggested power Symbol Tamb 125 ° C Tamb 105 ° C Tamb 80 ° C 3.3
5 предложений от 5 поставщиков
, MULTIPLE POWER MANAGEMENT FOR AU
L5965SQ-V0Y
546 ₽
L5965SQ-V0Y
575 ₽
IC Home
L5965SQ-V0Y
704 ₽
L5965SQ-V0Y
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
According to the below formula and considering TSD_TH thermal shutdown minimum threshold at 160 °C, the maximum suggested power dissipation is: PDISS_suggested = (TSHD -TAMB) / RTHJ-A
Table 5. Maximum suggested power Symbol Tamb 125 ° C Tamb 105 ° C Tamb 80 ° C
Rth j-a-2s 0.53 W 0.9 W 1.2 W Rth j-a-2s2p 1.1 W 1.8 W 2.6 W Rth j-a-2s2pvias 1.35 W 2.3 W 3.2 W
3.3 Electrical characteristics
VBAT1 supplies pre-BUCK1 circuitry the inner reference circuit (band-gap and oscillator) and VREF. VBAT2 supplies BUCK2, VSLDO supplies the LDO, VIN3 supplies BUCK3 and VIN4 supplies BUCK4. VBAT1,2 = 14 V, Tamb = –40 °C to 125 °C, unless otherwise specified.
Table 6. Electrical characteristics Symbol Parameter Test condition Min. Typ. Max. Unit General characteristics
VBAT1 Operating range – 4 14 32 V VBAT2 Operating range – 4 14 32 V All regulators off, VBAT1 = 14 V, non- I STANDBY mode total current consumption STANDBY1 – – 50 µA on VBAT1 supply inputs floating, current consumption from the supplies All regulators off, VBAT2 = 14 V, non- I STANDBY mode total current consumption STANDBY2 – – 1 µA on VBAT2 supply inputs floating, current consumption from the supplies Main BUCK only, V I BAT1-2 = 14 V, ACTIVE ACTIVE mode total current consumption – 10 – mA EXTSUP = 0 V All regulators ON, VBAT1-2 = 14 V, IACTIVE_ALL ACTIVE mode total current consumption Rising slope < 0.1V*ms, – 40 – mA EXTSUP=0 V
Supply monitors
Under-voltage threshold for V V BAT1 and UV Supply decreasing 5.3 5.8 6.3 V VBAT2 VUV_HYS Under-voltage hysteresis – – 0.2 0.4 V V OK threshold for VBAT1 or VBAT2, OK Supply increasing 5.5 6 6.5 V depending on which is the main regulator VOK_HYS OK-voltage hysteresis - - 0.2 0.4 V VOV Over-voltage threshold for VBAT1 and VBAT2 Supply increasing 30 32 34 V VOV_HYS Over-voltage hysteresis – – 2 2.4 V tUVOV_filter Over/under voltage filter time – 10 16 – µs VRESETB RESETB pin low output voltage IRESET = 1 mA 0.1 0.25 V TRESETB RESETB pulse duration – 4 10 16 µs VFAULT FAULT pin low output voltage IFAULT = 1 mA 0.1 0.25 V
DS12567
Rev 2 page 8/85
Document Outline 1 Overview 1.1 Simplified block diagram 1.2 Functional block diagram 2 Pins description 3 Electrical specifications 3.1 Absolute maximum ratings & operating voltage 3.2 Thermal data 3.2.1 Thermal resistance 3.2.2 Thermal warning and protection 3.3 Electrical characteristics 3.3.1 Electrical characteristic curves 4 Functional description 4.1 Programming by OTP 4.2 Voltage regulators and features description 4.2.1 VREG 4.2.2 Pre regulator BUCK1 4.2.3 Pre regulator BUCK2 4.2.4 Post regulator BUCK3 4.2.5 Post regulator BUCK4 4.2.6 BOOST 4.2.7 LDO 4.2.8 VREF 4.2.9 ADC 4.2.10 Wake up pin (WKUP) 4.2.11 Synchronizing pin (SYNC in/out) 4.2.12 Reset and Fault 4.2.13 Configurable watchdog and reset 4.2.14 Under-Voltage, Over-Voltage and Power-Good 4.2.15 Temperature control and VBATx voltage through internal ADC 4.2.16 Maximum Duty Cycle and Refresh Mode for Buck 4.2.17 Frequency-Hopping Spread Spectrum 5 SPI format and register mapping 5.1 SPI frame CRC generator 5.2 SPI registers mapping 5.2.1 SPI REG BUCK1 5.2.2 SPI REG BUCK2 5.2.3 SPI REG WD_REC_EN 5.2.4 SPI REG BUCK4 5.2.5 SPI REG BOOST VREF 5.2.6 SPI REG BUCK EN 5.2.7 SPI REG WD 5.2.8 SPI REG BUCK STAT1 5.2.9 SPI REG BUCK STAT2 5.2.10 SPI REG Fault Table PWUP 5.2.11 SPI REG ADC TH1 5.2.12 SPI REG ADC TH2 5.2.13 SPI REG ADC TH3 5.2.14 SPI REG ADC TH4 5.2.15 SPI REG ADC TH5 5.2.16 SPI REG ADC TH6 5.2.17 SPI REG ADC TH7 5.2.18 SPI REG ADC VBAT1 5.2.19 SPI REG ADC VBAT2 5.2.20 SPI REG OT Warning 5.2.21 SPI Fault STAT 5.2.22 SPI Silicon Version 5.2.23 SPI Device Identification 6 Device operating mode 6.1 Shutdown mode 6.2 Standby mode 6.3 INIT mode 6.4 REC mode 6.5 RAMPUP MAIN and SEC_UP 6.6 ACTIVE mode 6.7 OTP program mode 6.8 OTP bit mapping and register configuration 6.9 OTP (SAF) registers 6.9.1 SAF_REG_OP 6.9.2 SAF_REG_CFG 6.9.3 SAF_REG_DI 6.9.4 SAF_REG_D0_Bit_Ts 6.9.5 SAF_REG_STAT 6.10 Power down phase 6.11 Power up programming 7 Functional safety requirements 7.1 Functions and safety mechanism related to safety requirements 7.2 System safety mechanism 8 Application information 8.1 External components calculation 8.1.1 BUCK1 controller 8.1.1.1 RSENSE 8.1.1.2 BUCK1 output inductor 8.1.1.3 BUCK1 output capacitor 8.1.1.4 BUCK1 bootstrap capacitor 8.1.1.5 BUCK1 compensation network 8.1.2 BUCK2 controller 8.1.2.1 BUCK2 output inductor 8.1.2.2 BUCK2 output capacitor 8.1.2.3 BUCK2 compensation network 8.1.3 BUCK3, BUCK4 8.1.3.1 Output inductor and capacitor 8.1.3.2 Bootstrap capacitor for BUCK3 and BUCK4 8.1.3.3 Input capacitor 8.1.4 BOOST 8.1.4.1 BOOST output inductor 8.1.4.2 BOOST output capacitor 8.1.4.3 BOOST compensation network 8.1.4.4 Output diode for the BOOST converter 8.1.4.5 Input capacitor selection 8.2 PCB Layout example (BUCK1 as main regulator) 9 Package information 9.1 VFQFPN-48 (7x7x1.0 mm - opt. D) package information 9.2 VFQFPN-48 (7x7x1.0) marking information Revision history
