LTC3447 UUUPI FU CTIO SVOUT (Pin 1): Output Voltage Sensing Pin. An internal SW (Pin 6): Switch Node Connector to Inductor. This pin resistor divider provides the divided down feedback refer- connects the drains of the internal main and synchronous ence for comparison. power MOSFET switches. GND (Pin 2): Ground for all Circuits Excluding the Internal RUN (Pin 7): Run Control Input. Forcing pin above 1.5V Synchronous Power NFET. enables the part. Forcing the pin below 0.3V shuts down the device. In shutdown, all functions are disabled draw- FB (Pin 3): Feedback Sensing Pin for the Optional External ing <1µA of supply current. Do not leave the RUN pin Feedback Resistors. Must be tied to VIN if there are no fl oating. external feedback resistors. SCL (Pin 8): I2C Clock Input. PGOOD (Pin 4): Fault Report. Open drain driver sinks cur- rent when VOUT is 10% out of tolerance. Blanking during VCCD (Pin 9) : I2C Power Rail. DAC changes can be enabled via the I2C. SDA (Pin 10): I2C Data Input. VIN (Pin 5): Main Supply Pin. Must be closely decoupled Exposed Pad (Pin 11) : Ground. Must be connected to to GND with a 2.2µF or greater capacitor. PCB ground for electrical contact and optimized thermal performance. WBLOCK DIAGRA VIN CIN RUN VOUT 6-BIT DAC SW VCCD SLEW SW VDAC + SOFT-START BUCK C SDA V REGULATOR OUT DAC REF I2C 1.3R – BURST SCL V MUX FB LOAD BURST R BLANK REF R1 POWER UV REF PGOOD GOOD OV REF MUX FB R2 S DAC LTC3447 3447 BD Figure 2. LTC3447 High Level Block Diagram 3447f 6
