Источники питания Keen Side
Datasheet LT1938 (Analog Devices) - 9
Описание25V, 2.2A, 2.8MHz Step-Down Switching Regulator
Страниц / Страница24 / 9 — OPERATION
Формат / Размер файлаPDF / 271 Кб
OPERATION
OPERATION
28 предложений от 16 поставщиков
LT1938EDD#TRPBF
231 ₽
LT1938EDD#TRPBF
269 ₽
LIXINC Electronics
LT1938EDD#TRPBF
от 543 ₽
СПИ-Групп
LT1938EDD#TRPBF
LT1938
OPERATION
The LT1938 is a constant frequency, current mode step- This improves efficiency. The RUN/SS pin is used to place down regulator. An oscillator, with frequency set by RT, the LT1938 in shutdown, disconnecting the output and enables an RS flip-flop, turning on the internal power reducing the input current to less than 1µA. switch. An amplifier and comparator monitor the current The switch driver operates from either the input or from flowing between the VIN and SW pins, turning the switch the BOOST pin. An external capacitor and diode are used off when this current reaches a level determined by the to generate a voltage at the BOOST pin that is higher than voltage at VC. An error amplifier measures the output the input supply. This allows the driver to fully saturate voltage through an external resistor divider tied to the FB the internal bipolar NPN power switch for efficient pin and servos the VC pin. If the error amplifier’s output operation. increases, more current is delivered to the output; if it decreases, less current is delivered. An active clamp on the The oscillator reduces the LT1938’s operating frequency VC pin provides current limit. The VC pin is also clamped to when the voltage at the FB pin is low. This frequency the voltage on the RUN/SS pin; soft-start is implemented foldback helps to control the output current during startup by generating a voltage ramp at the RUN/SS pin using an and overload. external resistor and capacitor. The LT1938 contains a power good comparator which trips An internal regulator provides power to the control cir- when the FB pin is at 90% of its regulated value. The PG cuitry. The bias regulator normally draws power from the output is an open-collector transistor that is off when the VIN pin, but if the BIAS pin is connected to an external output is in regulation, allowing an external resistor to pull voltage higher than 3V bias power will be drawn from the the PG pin high. Power good is valid when the LT1938 is external source (typically the regulated output voltage). enabled and VIN is above 3.6V. 1938fa 9 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL ChARACTERISTICS TYPICAL PERFORMANCE ChARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION TYPICAL APPLICATION RELATED PARTS
