Datasheet LT3688 (Analog Devices) - 3
ОписаниеDual 800mA Step-Down Switching Regulator with Power-On Reset and Watchdog Timer
Страниц / Страница28 / 3 — ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over …
Формат / Размер файлаPDF / 430 Кб
ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
33 предложений от 16 поставщиков
, Dual 800mA Step-Down Switching Regulator with Power-On Reset and Watchdog Timer
LT3688EUF#TRPBF
464 ₽
IC Home
LT3688EUF#PBF
792 ₽
ЭИК
LT3688EUF#PBF
от 1 063 ₽
LT3688EUF PBF
LT3688
Th ELECTRICAL CHARACTERISTICS e
l
denotes the specifi cations which apply over the full operating junction temperature range, otherwise specifi cations are at TA = 25°C. VIN = 12V, unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Undervoltage Lockout l 3 3.5 3.8 V Quiescent Current from VIN VEN/UVLO = 0.3V 0.01 1 μA VBIAS = 5V, Not Switching l 65 105 μA VBIAS = 0V, Not Switching 235 310 μA Quiescent Current from BIAS VEN/UVLO = 0.3V 0.01 1 μA VBIAS = 5V, Not Switching l 155 200 μA VBIAS = 0V, Not Switching –5 –20 μA FB Voltage 0.790 0.800 0.810 V l 0.784 0.814 V FB Pin Bias Current VFB = 0.800V l –3 –50 nA FB Voltage Line Regulation 5V < VIN < 36V 0.002 %/V Switching Frequency RT = 20k, VBST = 12V l 1.85 2.1 2.35 MHz RT = 110k, VBST = 12V l 460 500 540 kHz Minimum Off-Time (Note 4) VBST = 12V l 115 180 ns Switch Current Limit (Note 5) DC = 15% l 1.2 1.7 2.2 A Switch VCESAT ISW = 0.8A 280 mV Switch Leakage Current (Note 8) –0.01 –1 μA DA Current Limit l 0.9 1.2 1.6 A Boost Schottky Reverse Leakage VBIAS = 0V 0.01 2 μA Minimum BST Voltage above SW 2.15 2.5 V BST Pin Current ISW = 0.8A 15 25 mA EN/UVLO Threshold Voltage l 1.15 1.25 1.35 V EN/UVLO Input Current VEN/UVLO = 1.35V 0.3 μA VEN/UVLO = 1.15V 2.5 4 6 μA Threshold Current Hysteresis 2.5 3.7 5.5 μA RUN/SS Pin Current VRUN/SS = 0V –1.4 –2.8 –4 μA RUN/SS Switching Threshold 0.15 0.8 1 V SYNC Threshold Voltage 0.4 0.8 1.3 V VUV Reset Threshold % of FB Voltage, VFB Falling l 88 90 92 % tRST Reset Timeout Period CPOR = 4700pF l 21.2 23.5 25.8 ms tWDU Watchdog Window Upper Boundary CWDT = 1000pF l 18 20 22 ms tWDL Watchdog Window Lower Boundary CWDT = 1000pF l 0.8 1.25 1.6 ms tWDTO Watchdog Timeout Period CWDT = 1000pF 2.5 ms RST Output Voltage Low ISINK = 2.5mA, VFB = 0.6V l 0.2 0.4 V ISINK = 100μA, VFB = 0.6V l 0.01 0.3 V tUV UV Detect to RST Asserted VFB Set to 0.680V l 4 10 30 μs WDI Input Threshold l 0.4 0.95 1.3 V WDI Input Pull-Up Current –2 μA WDI Input Pulse Width l 300 ns WDE Threshold Voltage l 0.4 0.65 1 V WDE Input Pull-Down Current VWDE = 1.2V 3.5 μA WDO Output Voltage Low ISINK = 2.5mA l 0.2 0.4 V ISINK = 100μA l 0.01 0.3 V 3688f 3
