Datasheet LTC3607 (Analog Devices) - 2
ОписаниеDual 600mA 15V Monolithic Synchronous Step-Down DC/DC Regulator
Страниц / Страница20 / 2 — absoluTe MaxiMuM raTings. (Note 1). pin conFiguraTion. orDer inForMaTion …
Формат / Размер файлаPDF / 374 Кб
absoluTe MaxiMuM raTings. (Note 1). pin conFiguraTion. orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING*
13 предложений от 12 поставщиков
IC REG BUCK ADJ 0.6A DL 16MSOP / Conv DC-DC 4.5V to 15V Synchronous Step Down Single-Out 0.6V to 15V 0.6A...
LTC3607EMSE#TRPBF
112 ₽
LTC3607EMSE#TRPBF
148 ₽
ЗУМ-СМД
LTC3607EMSE#TRPBF
LTC3607EMSE#TRPBF
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
LTC3607
Operating Junction Temperature Range PVIN, SVIN Voltages .. –0.3V to 15V (Notes 2, 7) .. –40°C to 125°C RUN1, RUN2 Voltages ... –0.3V to (SVIN + 0.3V) Storage Temperature Range ... –65°C to 150°C VFB1, VFB2 Voltages ... –0.3V to 3.6V Lead Temperature (Soldering, 10 sec) MODE/SYNC Voltage ... –0.3V to 3.6V MSOP Package ...300°C PGOOD1, PGOOD2 Voltages .. –0.3V to 15V
pin conFiguraTion
TOP VIEW RUN1 V FB1 V FB2 RUN2 TOP VIEW 16 15 14 13 SV 1 IN 16 PGOOD1 MODE/SYNC 1 12 SGND PGND1 2 15 MODE/SYNC SW1 3 14 RUN1 PGOOD1 2 11 PGOOD2 17 PV 4 IN1 13 V 17 FB1 SV PV 5 12 V IN 3 PGND 10 SGND IN2 PGND FB2 SW2 6 11 RUN2 PGND1 4 9 PGND2 PGND2 7 10 SGND SGND 8 9 PGOOD2 5 6 7 8 MSE PACKAGE IN1 IN2 SW1 16-LEAD PLASTIC MSOP PV PV SW2 UD PACKAGE TJMAX = 125°C, θJA = 37°C/W, θJC = 10°C/W 16-LEAD (3mm × 3mm) PLASTIC QFN EXPOSED PAD (PIN 17) IS PGND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 68°C/W, θJC = 7.5°C/W EXPOSED PAD (PIN 17) IS PGND, MUST BE SOLDERED TO PCB
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3607EUD#PBF LTC3607EUD#TRPBF LFNB 16-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C (Note 2) LTC3607IUD#PBF LTC3607IUD#TRPBF LFNB 16-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C (Note 2) LTC3607EMSE#PBF LTC3607EMSE#TRPBF 3607 16-Lead Plastic MSOP –40°C to 125°C (Note 2) LTC3607IMSE#PBF LTC3607IMSE#TRPBF 3607 16-Lead Plastic MSOP –40°C to 125°C (Note 2) Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http:/ www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3607fb 2 For more information www.linear.com/LTC3607 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
