Datasheet LT1078, LT1079 (Analog Devices) - 5
ОписаниеMicropower, Dual and Quad, Single Supply, Precision Op Amps
Страниц / Страница20 / 5 — ELECTRICAL CHARACTERISTICS VS =. 15V, TA = 25. C unless otherwise noted. …
Формат / Размер файлаPDF / 618 Кб
ELECTRICAL CHARACTERISTICS VS =. 15V, TA = 25. C unless otherwise noted. LT1078C/LT1079C. LT1078I/LT1079I. LT1078AC/LT1079AC
ELECTRICAL CHARACTERISTICS VS = 15V, TA = 25 C unless otherwise noted LT1078C/LT1079C LT1078I/LT1079I LT1078AC/LT1079AC
35 предложений от 22 поставщиков
LIXINC Electronics
LT1079SW#TRPBF
от 350 ₽
LT1079SW#PBF
365 ₽
ЗУМ-СМД
LT1079SW#TRPBF
LifeElectronics
LT1079SW-AE
LT1078/LT1079
15V, TA = 25
C unless otherwise noted. LT1078C/LT1079C LT1078I/LT1079I LT1078AC/LT1079AC LT1078M/LT1079M LT1078AM/LT1079AM LT1078S8/LT1079SW SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage (Including LT1078IS8/LT1078S8) 50 250 70 350 μV LT1079ISW/LT1079SW 80 500 μV IOS Input Offset Current 0.05 0.25 0.05 0.35 nA IB Input Bias Current 6 8 6 10 nA Input Voltage Range 13.5 13.8 13.5 13.8 V –15.0 –15.3 –15.0 –15.3 V CMRR Common Mode Rejection Ratio VCM = 13.5V, –15V 100 114 97 114 dB PSRR Power Supply Rejection Ratio VS = 5V, 0V to ±18V 102 114 100 114 dB AVOL Large-Signal Voltage Gain VO = ±10V, RL = 50k 1000 5000 1000 5000 V/mV VO = ±10V, RL = 2k 400 1100 300 1100 V/mV VOUT Maximum Output Voltage RL = 50k ±13.0 ±14.0 ±13.0 ±14.0 V Swing RL = 2k ±11.0 ±13.2 ±11.0 ±13.2 V SR Slew Rate 0.06 0.10 0.06 0.10 V/μs IS Supply Current per Amplifier 46 65 47 75 μA
The
denotes the specifications which apply over the temperature range – 40
C
TA
85
C for I grades, – 55
C
TA
125
C for AM/M grades. VS =
15V unless otherwise noted. LT1078I/LT1079I LT1078AM/LT1079AM LT1078M/LT1079M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage (Including LT1078IS8) ● 90 430 120 600 μV LT1079ISW ● 130 825 μV ΔVOS Input Offset Voltage Drift ● 0.5 1.8 0.6 2.5 μV/°C ΔT (Note 6) LT1078IS8 ● 0.7 3.8 μV/°C LT1079ISW ● 0.8 5.0 μV/°C IOS Input Offset Current ● 0.07 0.50 0.07 0.70 nA LT1078I/LT1079I ● 0.1 1.0 nA IB Input Bias Current ● 7 10 7 12 nA AVOL Large-Signal Voltage Gain VO = ±10V, RL = 5k ● 200 700 150 700 V/mV CMRR Common Mode Rejection Ratio VCM = 13V, –14.9V ● 94 110 90 110 dB PSRR Power Supply Rejection Ratio VS = 5V, 0V to ±18V ● 98 110 94 110 dB Maximum Output Voltage Swing RL = 5k ● ±11.0 ±13.5 ±11.0 ±13.5 V IS Supply Current per Amplifier ● 52 80 54 95 μA 10789fe 5
