Datasheet LT1801, LT1802 (Analog Devices) - 7
ОписаниеQuad 80MHz, 25V/µs Low Power Rail-to-Rail Input and Output Precision Op Amps
Страниц / Страница20 / 7 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 354 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range
32 предложений от 15 поставщиков
LT1802CS#TRPBF
256 ₽
LT1802CS#TRPBF
362 ₽
LT1802CS#TRPBF
от 378 ₽
LT1802CS#TRPBF
LT1801/LT1802
l
denotes the specifi cations which apply over the temperature range of 0°C < TA < 70°C. VS = ± 5V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V – OS Input Offset Voltage VCM = VS l 200 800 μV V – l CM = VS (MS8) 220 1000 μV V – l CM = VS (DD) 290 1300 μV V + l CM = VS 0.75 4 mV ΔV – + OS Input Offset Shift VCM = VS to VS – 1.5V l 45 675 μV Input Offset Voltage Match V – CM = VS l 240 1500 μV (Channel-to-Channel) (Note 9) V – l CM = VS (MS8) 300 1700 μV V – l CM = VS (DD) 340 1950 μV VOS TC Input Offset Voltage Drift (Note 8) l 1.5 5 μV/°C I – B Input Bias Current VCM = VS + 1V l 30 300 nA V + CM = VS – 0.2V l 450 2000 nA Input Bias Current Match V – CM = VS + 1V l 25 400 nA (Channel-to-Channel) (Note 9) V + CM = VS – 0.2V l 25 700 nA I – OS Input Offset Current VCM = VS + 1V l 25 300 nA V + CM = VS – 0.2V l 25 300 nA AVOL Large-Signal Voltage Gain VO = –4V to 4V, RL = 1k l 15 55 V/mV VO = –2V to 2V, RL = 100Ω l 2 5 V/mV CMRR Common Mode Rejection Ratio V – CM = VS to 3.5V l 82 105 dB CMRR Match (Channel-to-Channel) (Note 9) V – CM = VS to 3.5V l 76 105 dB Input Common Mode Range l V – + S VS V PSRR Power Supply Rejection Ratio V + – S = 2.5V to 10V, VS = 0V l 74 91 dB PSRR Match (Channel-to-Channel) (Note 9) V + – S = 2.5V to 10V, VS = 0V l 68 93 dB VOL Output Voltage Swing Low (Note 7) No Load l 17 80 mV I l SINK = 5mA 105 250 mV I l SINK = 20mA 250 575 mV VOH Output Voltage Swing High (Note 7) No Load l 25 90 mV I l SOURCE = 5mA 150 310 mV I l SOURCE = 20mA 600 975 mV ISC Short-Circuit Current l 22.5 45 mA IS Supply Current per Amplifi er l 2.4 4 mA GBW Gain Bandwidth Product Frequency = 2MHz l 70 MHz SR Slew Rate AV = – 1, RL = 1k, VO = ±4V, l 20 V/μs Measured at VO = ±2V
The
l
denotes the specifi cations which apply over the temperature range of – 40°C < TA < 85°C. VS = ±5V, VCM = 0V, VOUT = 0V, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V – OS Input Offset Voltage VCM = VS l 350 1000 μV V – l CM = VS (MS8) 350 1200 μV V – l CM = VS (DD) 350 1500 μV V + l CM = VS 0.75 5 mV ΔV – + OS Input Offset Shift VCM = VS to VS – 1.5V l 50 750 μV Input Offset Voltage Match V – CM = VS l 280 1700 μV (Channel-to-Channel) (Note 9) V – l CM = VS (MS8) 380 1900 μV V – l CM = VS (DD) 410 2100 μV 18012fc 7
