Datasheet LT6233, LT6233-10, LT6234, LT6235 (Analog Devices) - 10
Описание60MHz, Rail-to-Rail Output, 1.9nV/√Hz, 1.2mA Op Amp Family
Страниц / Страница24 / 10 — elecTrical characTerisTics Note 7:. Note 9:. Note 8:. Note 10:. Typical …
Формат / Размер файлаPDF / 792 Кб
elecTrical characTerisTics Note 7:. Note 9:. Note 8:. Note 10:. Typical perForMance characTerisTics. (LT6233/LT6234/LT6235)
elecTrical characTerisTics Note 7: Note 9: Note 8: Note 10: Typical perForMance characTerisTics (LT6233/LT6234/LT6235)
35 предложений от 19 поставщиков
Микросхема Буферный усилитель, Op Amp Quad GP R-R O/P ±6.3V/12.6V Automotive 16Pin SSOP N
ЧипСити
LT6235IGN
402 ₽
727GS
LT6235IGN#TRPBF
от 525 ₽
LT6235IGN#PBF
LT6235IGN#TRPBF
LT6233/LT6233-10 LT6234/LT6235
Minimum supply voltage is guaranteed by power supply rejection
Note 9:
Full-power bandwidth is calculated from the slew rate: ratio test. FPBW = SR/2πVP
Note 8:
Output voltage swings are measured between the output and
Note 10:
This parameter is not 100% tested. power supply rails.
Typical perForMance characTerisTics (LT6233/LT6234/LT6235) Supply Current vs Supply Voltage Offset Voltage vs Input Common VOS Distribution (Per Amplifier) Mode Voltage
60 2.0 500 VS = 5V, 0V VS = 5V, 0V VCM = V+/2 400 50 S8 T 300 1.5 A = 125°C 200 40 TA = 25°C 100 30 1.0 0 T –100 A = –55°C NUMBER OF UNITS 20 –200 T SUPPLY CURRENT (mA) A = –55°C 0.5 OFFSET VOLTAGE (µV) 10 –300 TA = 25°C –400 TA = 125°C 0 0 –500 –200 –150 –100 –50 0 50 100 150 200 0 2 4 6 8 10 12 14 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 INPUT OFFSET VOLTAGE (µV) TOTAL SUPPLY VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 623345 GO1 623345 GO2 623345 GO3
Input Bias Current Output Saturation Voltage vs Common Mode Voltage Input Bias Current vs Temperature vs Load Current (Output Low)
6 10 V 6 S = 5V, 0V VS = 5V, 0V VS = 5V, 0V 5 5 1 4 4 3 0.1 T T A = 125°C A = –55°C 3 2 TA = –55°C 2 VCM = 4V 0.01 1 TA = 125°C V 1 CM = 1.5V TA = 25°C INPUT BIAS CURRENT (µA) 0 TA = 25°C INPUT BIAS CURRENT (µA) 0.001 –1 0 OUTPUT SATURATION VOLTAGE (V) –2 –1 0.0001 –1 0 1 2 3 4 5 6 –50 –25 0 25 50 75 100 125 0.01 0.1 1 10 100 COMMON MODE VOLTAGE (V) TEMPERATURE (°C) LOAD CURRENT (mA) 623345 GO4 623345 GO5 623345 GO6 623345fc 10 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
