Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet LT1253, LT1254 (Analog Devices) - 7
ОписаниеLow Cost Dual and Quad Video Amplifiers
Страниц / Страница8 / 7 — APPLICATIO S I FOR ATIO. MAX POWER. at MAX TA. SI PLIFIED SCHE ATIC. One …
Формат / Размер файлаPDF / 222 Кб
APPLICATIO S I FOR ATIO. MAX POWER. at MAX TA. SI PLIFIED SCHE ATIC. One Amplifier. PACKAGE DESCRIPTIO
APPLICATIO S I FOR ATIO MAX POWER at MAX TA SI PLIFIED SCHE ATIC One Amplifier PACKAGE DESCRIPTIO
12 предложений от 11 поставщиков
OP Amp Quad Current Fdbk ±12V/24V 14-Pin SOIC N T/R
LT1254CS#TRPBF
393 ₽
LIXINC Electronics
LT1254CS#TRPBF
от 511 ₽
LT1254CS#TRPBF
661 ₽
ТаймЧипс
LT1254CS#TRPBF
LT1253/LT1254
U U W U APPLICATIO S I FOR ATIO
As a guideline to help in the selection of the LT1253/
MAX POWER
LT1254, the following table describes the maximum sup-
at MAX TA
ply voltage that can be used with each part based on the LT1253CN8 VS < ±14 (Abs Max) 0.800W following assumptions: LT1253CS8 VS < ±10.6 0.533W 1. The maximum ambient is 70°C. LT1254CN VS < ±11.4 1.143W 2. The load is a double-terminated video cable, 150Ω. LT1254CS VS < ±7.6 0.727W 3. The maximum output voltage is 2V (peak or DC).
W W SI PLIFIED SCHE ATIC One Amplifier
V+ +IN –IN VOUT V– LT1253/54 • SS
U PACKAGE DESCRIPTIO Dimensions in inches (millimeters) unless otherwise noted. N8 Package 8-Lead Plastic DIP
0.400 (10.160) 0.300 – 0.320 0.045 – 0.065 0.130 ± 0.005 MAX (7.620 – 8.128) (1.143 – 1.651) (3.302 ± 0.127) 8 7 6 5 0.065 0.250 ± 0.010 (1.651) 0.009 – 0.015 TYP (6.350 ± 0.254) 0.125 (0.229 – 0.381) (3.175) 0.020 +0.025 0.045 ± 0.015 MIN (0.508) 0.325 1 2 3 4 –0.015 MIN (1.143 ± 0.381) +0.635 8.255 ( ) –0.381 0.100 ± 0.010 0.018 ± 0.003 (2.540 ± 0.254) (0.457 ± 0.076) N8 0392 Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no represen- tation that the interconnection of its circuits as described herein will not infringe on existing patent rights. 7
