Клеммные колодки Keen Side
Datasheet LT1398, LT1399, LT1399HV (Analog Devices) - 5
ОписаниеLow Cost Dual and Triple 300MHz Current Feedback Amplifiers with Shutdown
Страниц / Страница16 / 5 — ELECTRICAL CH. ARA TERISTICS (LT1399HV). The
ВерсияA
Формат / Размер файлаPDF / 441 Кб
ELECTRICAL CH ARA TERISTICS (LT1399HV) The
LT1399IS#TRPBF
138 ₽
IC Home
LT1399IS#TRPBF
385 ₽
LT1399IS#TRPBF
402 ₽
Элитан
LT1399IS
1 716 ₽
LT1398/LT1399/LT1399HV
ELECTRICAL CH C ARA TERISTICS (LT1399HV) The
denotes specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25
C. For each amplifier: VCM = 0V, VS =
7.5V, EN = 0V, pulse tested, unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SR Slew Rate (Note 6) AV = 10, RL = 150Ω, VS = ±5V 500 800 V/µs tON Turn-On Delay Time (Note 7) RF = RG = 324Ω, RL = 100Ω, VS = ±5V 30 75 ns tOFF Turn-Off Delay Time (Note 7) RF = RG = 324Ω, RL = 100Ω, VS = ±5V 40 100 ns tr, tf Small-Signal Rise and Fall Time RF = RG = 324Ω, RL = 100Ω, VOUT = 1VP-P, 1.3 ns VS = ±5V tPD Propagation Delay RF = RG = 324Ω, RL = 100Ω, VOUT = 1VP-P, 2.5 ns VS = ±5V os Small-Signal Overshoot RF = RG = 324Ω, RL = 100Ω, VOUT = 1VP-P, 10 % VS = ±5V tS Settling Time 0.1%, AV = – 1V, RF = RG = 309Ω, RL = 150Ω, 25 ns VS = ±5V dG Differential Gain (Note 8) RF = RG = 324Ω, RL = 150Ω, VS = ±5V 0.13 % dP Differential Phase (Note 8) RF = RG = 324Ω, RL = 150Ω, VS = ±5V 0.10 DEG
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 6:
Slew rate is measured at ±2V on a ±3V output signal. of a device may be impaired.
Note 7:
Turn-on delay time (tON) is measured from control input to
Note 2:
This parameter is guaranteed to meet specified performance appearance of 1V at the output, for VIN = 1V. Likewise, turn-off delay through design and characterization. It has not been tested. time (tOFF) is measured from control input to appearance of 0.5V on
Note 3:
A heat sink may be required depending on the power supply the output for VIN = 0.5V. This specification is guaranteed by design voltage and how many amplifiers have their outputs short circuited. and characterization.
Note 4:
The LT1398C/LT1399C/LT1399HVC are guaranteed to meet
Note 8:
Differential gain and phase are measured using a Tektronix specified performance from 0°C to 70°C and are designed, characterized TSG120YC/NTSC signal generator and a Tektronix 1780R Video and expected to meet these extended temperature limits, but are not tested Measurement Set. The resolution of this equipment is 0.1% and 0.1°. or QA sampled at – 40°C and 85°C. The LT1399I is guaranteed to meet Ten identical amplifier stages were cascaded giving an effective specified performance from –40°C to 85°C. resolution of 0.01% and 0.01°.
Note 5:
T
Note 9:
The LT1398C, LT1398I, LT1399C, LT1399I, LT1399HVC and J is calculated from the ambient temperature TA and the power dissipation P LT1399HVI are guaranteed functional over the operating temperature D according to the following formula: LT1398CS, LT1399CS, LT1399IS, LT1399HVCS: range of –40°C to 85°C. TJ = TA + (PD • 100°C/W) LT1399CGN, LT1399IGN: TJ = TA + (PD • 120°C/W)
W U TYPICAL AC PERFOR A CE SMALL SIGNAL SMALL SIGNAL SMALL SIGNAL VS (V) AV RL (
) RF (
) RG (
) – 3dB BW (MHz) 0.1dB BW (MHz) PEAKING (dB)
±5 1 100 365 – 300 150 0.05 ±5 2 100 324 324 300 150 0 ±5 – 1 100 309 309 300 150 0 sn13989 13989fas 5
