Datasheet LT3430, LT3430-1 (Analog Devices) - 2
Описание | High Voltage, 3A, 200kHz/100kHz Step-Down Switching Regulators |
Страниц / Страница | 28 / 2 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). Order … |
Формат / Размер файла | PDF / 335 Кб |
Язык документа | английский |
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). Order Options. ELECTRICAL CHARACTERISTICS. The
LT3430/LT3430-1
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION (Note 1)
TOP VIEW Input Voltage (VIN) .. 60V BOOST Pin Above SW (Note 11) .. 35V GND 1 16 GND BOOST Pin Voltage ... 68V SW 2 15 SHDN V 3 14 SYNC SYNC Voltage ... 7V IN V 4 13 NC ⎯S⎯H⎯D⎯N Voltage .. 6V IN 17 SW 5 12 FB BIAS Pin Voltage ... 30V BOOST 6 11 VC FB Pin Voltage/Current .. 3.5V/2mA NC 7 10 BIAS Operating Junction Temperature Range GND 8 9 GND LT3430EFE (Notes 8, 10) .. –40°C to 125°C FE PACKAGE LT3430IFE (Notes 8, 10) .. –40°C to 125°C 16-LEAD PLASTIC TSSOP Storage Temperature Range ... –65°C to 150°C TJMAX = 125°C, θJA = 45°C/W, θJC = 10°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB Lead Temperature (Soldering, 10 sec) .. 300°C ORDER PART NUMBER FE PART MARKING LT3430EFE 3430EFE LT3430IFE 3430IFE LT3430EFE-1 3430EFE-1 LT3430IFE-1 3430IFE-1
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specifi ed with wider operating temperature ranges.
ELECTRICAL CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TJ = 25°C. VIN = 15V, VC = 1.5V,
S
H
D
N = 1V, BOOST = Open Circuit, SW = Open Circuit, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Reference Voltage (VREF) VOL + 0.2 ≤ VC ≤ VOH – 0.2 1.204 1.219 1.234 V 5.5V ≤ VIN ≤ 60V ● 1.195 1.243 FB Input Bias Current ● –0.2 –1.5 µA Error Amp Voltage Gain (Note 2) 200 400 V/V Error Amp gm dl (VC) = ±10µA 1650 2200 3300 µMho ● 1000 4200 µMho VC to Switch gm 3.4 A/V EA Source Current FB = 1V ● 125 225 450 µA EA Sink Current FB = 1.4V ● 100 225 500 µA VC Switching Threshold Duty Cycle = 0 0.9 V VC High Clamp ⎯S⎯H⎯D⎯N = 1V 2.1 V Switch Current Limit VC Open, Boost = VIN + 5V, FB = 1V –40°C ≤ TJ ≤ 25°C 3 5 6.5 A TJ = 125°C (Note 9) 2.5 4 5.5 A Switch On Resistance ISW = 2.5A, Boost = VIN + 5V (Note 7) 0.1 0.14 Ω 0.18 Ω Maximum Switch Duty Cycle (LT3430) FB = 1V 93 96 % ● 90 % 34301fa 2
