Datasheet LT6010 (Analog Devices) - 2
Описание135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp with Shutdown
Страниц / Страница16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL …
Формат / Размер файлаPDF / 304 Кб
ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO ELECTRICAL CHARACTERISTICS The
20 предложений от 18 поставщиков
LT6010ACDD#PBF
78 ₽
LT6010ACDD#TRPBF
86 ₽
IC Home
LT6010ACDD#TRPBF
268 ₽
ЭИК
LT6010ACDD#PBF
771 ₽
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
LT6010
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Total Supply Voltage (V+ to V–) .. 40V Maximum Junction Temperature Differential Input Voltage (Note 2) .. 10V DD Package ... 125°C Input Voltage, Shutdown Voltage ... V+ to V– SO-8 Package .. 150°C Input Current (Note 2) ... ±10mA Storage Temperature Range Output Short-Circuit Duration (Note 3) ... Indefinite DD Package ... – 65°C to 125°C Operating Temperature Range (Note 4) .. – 40°C to 85°C SO-8 Package .. – 65°C to 150°C Specified Temperature Range (Note 5) ... – 40°C to 85°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER PART ORDER PART TOP VIEW NUMBER TOP VIEW NUMBER NULL 1 8 NULL NULL 1 8 NULL LT6010CDD LT6010CS8 –IN 2 7 V+ –IN 2 7 V+ – – LT6010IDD + LT6010IS8 + +IN 3 6 OUT LT6010ACDD +IN 3 6 OUT LT6010ACS8 V– 4 5 SHDN LT6010AIDD V– 4 5 SHDN LT6010AIS8 DD PART MARKING* S8 PACKAGE 8-LEAD PLASTIC SO S8 PART MARKING DD PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 190°C/W 6010 LADU TJMAX = 125°C, θJA = 160°C/W UNDERSIDE METAL INTERNALLY CONNECTED TO V– 6010I (PCB CONNECTION OPTIONAL) 6010A 6010AI *Temperature grades are identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VS = 5V, 0V; VCM = 2.5V; RL to 0V; SHDN = 0.2V, unless otherwise specified. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 7) LT6010AS8 10 35 µV TA = 0°C to 70°C ● 60 µV TA = –40°C to 85°C ● 75 µV LT6010S8 20 55 µV TA = 0°C to 70°C ● 85 µV TA = –40°C to 85°C ● 110 µV LT6010ADD 20 60 µV TA = 0°C to 70°C ● 85 µV TA = –40°C to 85°C ● 100 µV LT6010DD 30 80 µV TA = 0°C to 70°C ● 110 µV TA = –40°C to 85°C ● 135 µV ∆VOS/∆T Input Offset Voltage Drift (Note 6) LT6010AS8, LT6010S8 ● 0.2 0.8 µV/°C LT6010ADD,LT6010DD ● 0.2 1.3 µV/°C sn6010 6010fs 2
