Datasheet LTM8050 (Analog Devices) - 7
Описание58V, 2A Step-Down µModule Regulator
Страниц / Страница24 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS Operating conditions are per Table 1 …
Формат / Размер файлаPDF / 442 Кб
TYPICAL PERFORMANCE CHARACTERISTICS Operating conditions are per Table 1 and. TA = 25°C, unless otherwise noted
TYPICAL PERFORMANCE CHARACTERISTICS Operating conditions are per Table 1 and TA = 25°C, unless otherwise noted
23 предложений от 12 поставщиков
Источники питания - Для монтажа на плату Преобразователи DC/DC
LIXINC Electronics
LTM8050EY#PBF
от 1 210 ₽
ЧипСити
LTM8050EY#PBF
2 525 ₽
ЭИК
LTM8050EY#PBF
от 5 126 ₽
LTM8050EY PBF
LTM8050
TYPICAL PERFORMANCE CHARACTERISTICS Operating conditions are per Table 1 and TA = 25°C, unless otherwise noted. Minimum VIN vs Output Current Minimum VIN vs Output Current Minimum VIN vs Output Current 3.3VOUT, BIAS = VOUT 5VOUT, BIAS = VOUT 8VOUT, BIAS = VOUT
6.0 7.55 12.5 RUNNING 7.50 TO START, RUN CONTROL 12.0 5.5 TO START, RUN = V 7.45 IN 11.5 7.40 5.0 11.0 (V) (V) (V) IN IN 7.35 IN 10.5 4.5 7.30 10.0 7.25 9.5 MINIMUM V 4.0 MINIMUM V 7.20 MINIMUM V 9.0 7.15 3.5 RUNNING 8.5 RUNNING TO START, RUN CONTROL 7.10 8.0 TO START, RUN CONTROL TO START, RUN = VIN TO START, RUN = VIN 3.0 7.05 7.5 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8050 G28 8050 G29 8050 G30
Minimum VIN vs Output Current Minimum VIN vs Output Current Minimum VIN vs Output Current 12VOUT, BIAS = VOUT 18VOUT, BIAS = VOUT 24VOUT, BIAS = 5V
17 26 35 34 16 25 33 24 32 15 (V) (V) (V) IN IN 23 IN 31 14 30 22 29 MINIMUM V 13 MINIMUM V MINIMUM V 21 28 27 12 RUNNING TO START, RUN CONTROL 20 26 TO START, RUN = VIN 11 19 25 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 0 0.5 1.0 1.5 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8050 G31 8050 G32 8050 G33
Minimum VIN vs Output Current Minimum VIN vs Output Current Minimum VIN vs Output Current –3.3VOUT, BIAS = GND –5VOUT, BIAS = GND –8VOUT, BIAS = GND
30 25 25 RUNNING RUNNING RUNNING TO START, RUN CONTROL TO START, RUN CONTROL TO START, RUN CONTROL 25 TO START, RUN = VIN TO START, RUN = V TO START, RUN = V 20 IN 20 IN 20 (V) (V) (V) IN IN 15 IN 15 15 10 10 MINIMUM V 10 MINIMUM V MINIMUM V 5 5 5 0 0 0 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 0 0.5 1.0 1.5 2.0 OUTPUT CURRENT (A) OUTPUT CURRENT (A) OUTPUT CURRENT (A) 8050 G34 8050 G35 8050 G36 8050fc For more information www.linear.com/LTM8050 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Related Parts Design Resources
