Клеммные колодки Keen Side
Datasheet LTC6655 (Analog Devices) - 4
Описание0.25ppm Noise, Low Drift Precision References
Страниц / Страница26 / 4 — available opTions. OUTPUT VOLTAGE. INITIAL ACCURACY. TEMPERATURE …
Формат / Размер файлаPDF / 1.6 Мб
available opTions. OUTPUT VOLTAGE. INITIAL ACCURACY. TEMPERATURE COEFFICIENT. PART NUMBER†. elecTrical characTerisTics. The
available opTions OUTPUT VOLTAGE INITIAL ACCURACY TEMPERATURE COEFFICIENT PART NUMBER† elecTrical characTerisTics The
32 предложений от 16 поставщиков
V-Ref Precision 5V 5mA 8-Pin CLLCC Tray / IC VREF SERIES 5V 8CLCC
ЧипСити
LTC6655BHLS8-5#PBF
1 213 ₽
LTC6655BHLS8-5#PBF
1 604 ₽
LTC6655BHLS8-5#PBF
от 2 513 ₽
LTC6655BHLS8-5 PBF
LTC6655
1.250 0.025% 2ppm/°C LTC6655BHMS8-1.25 0.05% 5ppm/°C LTC6655CHMS8-1.25 2.048 0.025% 2ppm/°C LTC6655BHMS8-2.048 0.05% 5ppm/°C LTC6655CHMS8-2.048 2.500 0.025% 2ppm/°C LTC6655BHMS8-2.5 0.05% 5ppm/°C LTC6655CHMS8-2.5 0.025% 2ppm/°C LTC6655BHLS8-2.5 0.05% 5ppm/°C LTC6655CHLS8-2.5 3.000 0.025% 2ppm/°C LTC6655BHMS8-3.0 0.05% 5ppm/°C LTC6655CHMS8-3.0 3.300 0.025% 2ppm/°C LTC6655BHMS8-3.3 0.05% 5ppm/°C LTC6655CHMS8-3.3 4.096 0.025% 2ppm/°C LTC6655BHMS8-4.096 0.05% 5ppm/°C LTC6655CHMS8-4.096 0.025% 2ppm/°C LTC6655BHLS8-4.096 0.05% 5ppm/°C LTC6655CHLS8-4.096 5.000 0.025% 2ppm/°C LTC6655BHMS8-5 0.05% 5ppm/°C LTC6655CHMS8-5 0.025% 2ppm/°C LTC6655BHLS8-5 0.05% 5ppm/°C LTC6655CHLS8-5 †See Order Information section for complete part number listing.
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = VOUT + 0.5V, VOUT_S connected to VOUT_F , unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage LTC6655B –0.025 0.025 % LTC6655C –0.05 0.05 % Output Voltage Temperature Coefficient LTC6655B l 1 2 ppm/°C (Note 4) LTC6655C l 2.5 5 ppm/°C Line Regulation VOUT + 0.5V ≤ VIN ≤ 13.2V, SHDN = 2V 5 25 ppm/V l 40 ppm/V Load Regulation (Note 5) ISOURCE = 5mA LTC6655MS8 3 ppm/mA l 15 ppm/mA LTC6655LS8 3 ppm/mA l 15 ppm/mA ISINK = 5mA LTC6655MS8 10 ppm/mA l 30 ppm/mA LTC6655LS8 20 ppm/mA l 45 ppm/mA Operating Voltage (Note 6) LTC6655-1.25, LTC6655-2.048, LTC6655-2.5 ISOURCE = 5mA, VOUT Error ≤ 0.1% l 3 13.2 V LTC6655-3, LTC6655-3.3, LTC6655-4.096, LTC6655-5 ISOURCE = ±5mA, VOUT Error ≤ 0.1% l VOUT + 0.5 13.2 V IOUT = 0mA, VOUT Error ≤ 0.1% l VOUT + 0.2 13.2 V 6655ff 4 For more information www.linear.com/LTC6655 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
