Datasheet LT3439 (Analog Devices) - 2
ОписаниеSlew Rate Controlled Ultralow Noise 1A Isolated DC/DC Transformer Driver
Страниц / Страница12 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL …
Формат / Размер файлаPDF / 196 Кб
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL CHARACTERISTICS. The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) ELECTRICAL CHARACTERISTICS The
43 предложений от 20 поставщиков
LT3439EFE#TRPBF
от 162 ₽
727GS
LT3439EFE#TRPBF
от 193 ₽
LT3439EFE#PBF
241 ₽
LifeElectronics
LT3439EFE
LED-драйверы MOSO – надежные и качественные ИП в линейке поставок КОМПЭЛ
LT3439
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
V TOP VIEW IN Voltage ... 20V ORDER PART COL A, COL B Voltage ... 35V PGND 1 16 PGND NUMBER SHDN, SYNC Voltage .. 20V NC 2 15 NC Maximum Junction Temperature ... 150°C COL A 3 14 COL B LT3439EFE R 4 Operating Junction Temperature Range 13 SL VIN SYNC 5 12 NC (Note 2) .. – 40°C to 125°C C 6 11 T SHDN Storage Temperature Range .. – 65°C to 150°C FE PART R 7 10 T GND Lead Temperature (Soldering, 10 sec)... 300°C MARKING NC 8 9 NC FE PACKAGE 3439EFE 16-LEAD PLASTIC TSSOP TJMAX = 125°C, θJA = 40°C/ W NOTE: BACKSIDE OF PACKAGE CONNECTED TO GND Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 5V; RT = 16.9k; CT = 680pF; RSL = 16.9k; COL A, COL B, SHDN pins open, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Supply and Shutdown
VIN Operating Range ● 2.8 17.5 V VIN(MIN) Minimum Input Voltage 2.55 2.7 V IVIN Supply Current 2.8V ≤ VIN ≤ 17.5V ● 12 mA IVIN(SHDN) Supply Current in Shutdown Mode 2.8V ≤ VIN ≤ 17.5V, VSHDN = 0V 5 20 µA VSHDN(ON) Shutdown Turn-On Threshold 2.8V ≤ VIN ≤ 17.5V ● 1.3 1.4 V VSHDN(OFF) Shutdown Turn-Off Threshold 2.8V ≤ VIN ≤ 17.5V ● 1.20 1.26 V ISHDN Shutdown Pin Current Hysteresis 2.8V ≤ VIN ≤ 17.5V, VSHDN = 1.4V ● 10 20 40 µA
Oscillator and Sync
fMAX Oscillator Frequency ● 250 kHz fSYNC Synchronization Frequency Range ● 300 kHz VSYNC SYNC Pin Threshold ● 1.4 2.25 V RSYNC SYNC Pin Input Resistance 40 kΩ
Output Switches (COL A, COL B)
DC Switch Duty Cycle ● 50 % BV Output Switch Breakdown Voltage 2.8V ≤ VIN ≤ 17.5V ● 35 50 V RON Output Switch On Resistance ICOLA or ICOLB = 0.75A ● 0.5 0.95 Ω ILIM(MAX) Switch Current Limit 1.2 1.4 1.65 A
Slew Control
VSLEWR Output Voltage Slew Rising Edge Collector A or B 17 V/µs VSLEWF Output Voltage Slew Falling Edge Collector A or B 17 V/µs ISLEWR Output Current Slew Rising Edge Collector A or B 5 A/µs ISLEWF Output Current Slew Falling Edge Collector A or B 5 A/µs
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 2:
The LT3439E is guaranteed to meet performance specifications of a device may be impaired. from 0°C to 70°C. Specifications over the –40°C to 125°C operating junction temperature range are assured by design, characterization and correlation with statistical process controls. sn3439 3439fs 2
